DAB Radio logo
lolling123
England
Anyone know how to get the DAB logo uploaded?
I tried to put jpg onto SD card but I think the format was incorrect.
No documentation or help seems to be readily available.
I wouldn't have even cared about this but for the gaping empty box on the display.
Cheers in advance.
lolling123
England
I found the answer in the manual and am posting here in case anyone else needs to know. answer is 400x240 pixels (jpg,bmp or png). Alas a search for the "volkswagen station logos website" is less successful.
MK7STE
Hi,
I put together some logos for the BBC DAB Stations, see attached zip.
Cheers.
(two files due size limits of forum)
  • dab1.zip
  • dab2.zip
redfred
nottingham
Go to getdigitalradio.com right click on the logos you require and " save picture as" to a folder then transfer them to your sdhc card they are alreadt the right file size so you don't need to alter anything then just install as described on page 20 of your media book . Just finished doing mine it works a treat
haydnw
East Midlands
My German's a bit rusty, but this seems to be the VW link to station logo downloads:
http://www.volkswagen.de/de/models/golf_7/brochure/senderlogos.html
Confusingly, their PNG files are only 160px x 120px; although the manual does say that images up to 400px x 240px can be used so they may just be resized to 160px x 120px internally.
FWIW, I've tried PNG and JPG at 400px x 240px and neither have worked. However, JPGs at 393px square did work.
It seems you can delete the files off your SD card once you've set the station logos - my Golf 'remembered' the logos even without the SD card in the slot.
Matrick
UK
Thanks, that method worked perfectly for me, no image resizing needed :)
Boggle
UK
Although the units will accept most sizes of logo and 'fit' them to the buttons, I thought I'd share my collection of logos for anyone looking for some that match the exact specs needed in terms of size & transparency (transparent background gives a much nicer look on the on-screen buttons). Mainly national and a few Midlands based stations (as these are the one I get in my area)....
  • DAB Logos 200x120 Trans - Part 1.zip
  • DAB Logos 200x120 Trans - Part 2.zip
  • DAB Logos 200x120 Trans - Part 3.zip
  • DAB Logos 200x120 Trans - Part 4.zip
  • DAB Logos 200x120 Trans - Part 5.zip
  • DAB Logos 200x120 Trans - Part 6.zip
allyadam
Dundee, Scotland
Great post boggle - some of the best logos I've seen.. i live in Scotland so wanted to add a few more stations, can you tell me how you made those logos so i can match the transparent right sized effect.. Many thanks
Boggle
UK
I used Photoshop, but you could use any app that's capable of editing and saving png format files with transparency. Main thing is to have a canvas that's 200x120 pixels as this is the exact size required for the buttons (other sizes will work but they'll get distorted to fit). Ideally, you want to look for original logos with transparency (PNG's, not JPG's) but if you can't find them, you can use Photoshop etc. to erase the background colour). Finally, re-size the logo to fit on the canvas but be sure to maintain (or lock) the aspect ratio so it doesn't get distorted/stretched.
Hope that helps!
Avanti
UK
Do I have to unzip the file and put all the logos onto my card or will the car unzip the file ?
I can't remember as the stick is in the car, however whilst you are on the PC and able to unzip it there and then, that would be the way to go, rather than expect it to happen in the car, which it may do, but more likely not.
