eddiekranc
- Miami FL
So was doing my first auto x event last night, then when I finished my last run I decided screw it let me get one hit at the 1/4 drag. Once I finished the check engine popped up. I'll get the exact codes in a bit but obdelevn says it's the engine cooling bypass, also says cooling low performance and cooling electrical something can't remember right now.
Had an hour long drive back home, during the drive I kept it at 65mph, noticed the engine temp was rising pass the middle mark, pulled over and didn't see any leaks. Cleared the codes with obdeleven, restarted the infotainment system since that bastard controls everything and started driving again. Now the temp started dropping and held at around 160 f for the rest of the drive home, same for oil temp.
Anyone know where the bypass is to give it a look? All shops are closed and don't think warranty will cover it since I'm stage two and was prob due to the abuse at track.
