Old 01-16-2018, 08:21 PM   #86
Originally Posted by jedadiah View Post
My North American Golf TDI S doesn't have a 5th pin in the T17d housing, so I'll need to run a wire directly from my switch to the ABS unit. Does anyone know what the VW terminal that goes into the ABS connector is? MQS? MCON? Micro Timer? and if so then what wire gauge? Buying the terminals is way cheaper than buying repair wires.
Heres the best page I've ever found for identifying pins https://www.a4-freunde.com/showwiki....s+dazu+gehoert
Look at above post link to TPMS thread where I wired to ABS unit......also I used 0.5mm2 (cross sectional area not diameter)..is the choice of wire for these items & matched the OEM wires & the OEM repair wires are in different sizes & I think this was the thickest for that connector...
My Build:- Click Here
Old 01-17-2018, 04:18 PM   #87
jedadiah
Drives: '15 Golf TDI S
Thanks. I found it. I also noticed that you can see the terminal in the Ali express harness link a few pages back.
jedadiah is offline   Reply With Quote
Old 02-06-2018, 07:52 PM   #88
Hotwire
Drives: 2017 GSW Highline
I ordered the Aliexpress harness.. But its been almost 2 months for delivery. I have the instructions and Pin numbers. but I am not sure of the pin style for the connectors.
any idea how I figure out what style I need? i bought the two "Repair wires" suggested at the beginning of the thread. The wires go to the BCM plug C.
thank you very much
Hotwire is offline   Reply With Quote
Old 07-13-2018, 08:33 PM   #89
murtaza911
Drives: 2016 Golf 1.8t Tsi
Does this kit include everything I need? My car currently has no buttons at all (Base model golf)
https://www.aliexpress.com/item/Driv...ceBeautifyAB=0
Also, any idea if it's possible to repurpose the other buttons? I'd like to wire them up to a garage door opener hidden in the dash somewhere.
2016 Tsi 1.8t, 5spd, IS20, JB4, 3" Downpipe, GolfR Intercooler.
murtaza911 is offline   Reply With Quote
Old 07-13-2018, 09:27 PM   #90
[Also, any idea if it's possible to repurpose the other buttons? I'd like to wire them up to a garage door opener hidden in the dash somewhere.
Looks like it has all you need...& yes other people have repurposed one of the other buttons for a garage door opener..several threads on here about it...
Old 07-13-2018, 09:54 PM   #91
murtaza911
Great thanks!
Yeah I saw the other threads making a garage door opening, but didn't know if they used this switch or something else.
Old 07-30-2018, 03:30 PM   #92
carlosalicea
Drives: MKVII GTI
I need some help here.
I performed the change (bu the way passcode for the abs module is 40168), and it works with the side effect that when you flat out (full throttle) then the system activates ESC automatically.
I changed it back to 09 (stock) but the side effect stays.
I only wanted to be able to track the car without traction control and now I cannot.
Any help or direction will be appreciated.
Thanks.
Current: Silver MK7 Autobhan DSG - CTS DP forge blow off uni stage 2 301whp 328wtq
Spacers: 20mm B, 15mm F
Blistein PSS B14 coilovers
Hel SS brake lines, Motul 660 fluid, and EBC yellows.
carlosalicea is offline   Reply With Quote
Old 07-30-2018, 08:48 PM   #93
Thanks.
you cannot 100% turn off ESC ..the only way is to remove the fuse...then you get warning lights....
Old 09-29-2018, 03:00 AM   #94
x2001pmq
So Dave I finally had a chance to come back to this. My abs connector does not have a pin 39, the max is pin 38, any ideas?
x2001pmq is offline   Reply With Quote
Old 09-29-2018, 08:42 AM   #95
The Connector on the ABS unit (J104) is a 46 pin connector....& wires in 38, 44, 45, 46 etc..
Old 09-29-2018, 03:13 PM   #96
x2001pmq
I logged into Erwin and got the wiring diagram and connector pinout. For my car it has a 38 pin connector and the signal/esc is in pin 4 with a vi/gr wire.
My car is a NA 2016 vw golf tsi base model, perhaps that’s the reason for the difference
Old 09-29-2018, 07:29 PM   #97
I thought it might be the manual -vs- the electronic handbrake but the info I have still gives the same abs pin outs...it might be wrong..anyway at least you found the pin outs..
Old 01-05-2019, 09:39 AM   #98
Kykyhalim
Drives: Golf mk7
Hi golfdave.. i have successfully follow this esp off with button retrofit.. thank you !
I set to esp on — esp sport — esp off (bit 6 vcds) and it working.. only the button doesnt illuminate.. for button led, where should i connect wire pin 1 and pin 2 to ? The easy one ? Its because by default i dont have the button at all in left row of the dsg stick
Thanks
Kykyhalim is offline   Reply With Quote
Old 01-05-2019, 10:13 AM   #99
Thanks
Pin1 is to a main earth connection..nearest one you can find...Pin2 is a live connection from a grey wire.....from the same grey wire which feeds the electronic handbrake...
