Old 11-23-2017, 02:53 PM   #69
cgentil
cgentil's Avatar
Drives: Golf 7
Originally Posted by cgentil View Post
Hi,
It's possible to get more options on Infotainment without the button?
Now I only have
02 = ESC & ASR ON / ASR OFF / Blank (Standard for most Golf’s)
I'd like to make it working
05 = ESC & ASR ON / ASR OFF / ESC OFF
But I don't have the button, it's still possible to get this only on screen?
Anyway I tried to follow that instructions but byte 29 is empty, shows nothing.
Thanks.
Anyone? When I put the bit on byte 29 it gives me a error, my module doesn't support it?
Best Regards,
Chirag Geiantilal
'06 - Volkswagen Passat 3C 2.0 TDI Highline - 2009 - 2017
'12 - Volkswagen Golf VII 1.6 TDI Confortline - 2015 - ...
cgentil is offline   Reply With Quote
Old 11-23-2017, 04:09 PM   #70
Correct....the module isn't a high enough spec...
what are you using to do the coding..OBD11 or VCDS?
My Build:- Click Here
Old 11-23-2017, 04:24 PM   #71
cgentil
cgentil's Avatar
Drives: Golf 7
VCDS.
If you prefer I can post the error later and the module part no.
Best Regards,
Chirag Geiantilal
Old 11-23-2017, 04:26 PM   #72
VCDS.
that would be ok...
Old 11-23-2017, 04:30 PM   #73
cgentil
cgentil's Avatar
Drives: Golf 7
that would be ok...
ABS Brakes (J104)
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
It's possible?
Thanks.
Best Regards,
Chirag Geiantilal
Old 11-23-2017, 04:35 PM   #74
ABS Brakes (J104)
It's possible?
Thanks.
no other information from the ABS unit in the scan??? what version of VCDS are you using???
Old 11-23-2017, 04:45 PM   #75
cgentil
cgentil's Avatar
Drives: Golf 7
What information do you need?
It also says H75 0437
Best Regards,
Chirag Geiantilal
Old 11-23-2017, 04:48 PM   #76
A scan of the ABS module in a genuine VCDS will show the following:-
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62644000001579
Coding: 04FA8AA12425296E0380060941C82920512494C0608294F3F4 205078C002
Shop #: WSC 00028 028 00067
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 45819FDFC4A3C5091CD-8010
No fault code found.
Old 11-23-2017, 04:52 PM   #77
cgentil
cgentil's Avatar
Drives: Golf 7
A
Best Regards,
Chirag Geiantilal
Old 11-23-2017, 04:57 PM   #78
cgentil
cgentil's Avatar
Drives: Golf 7
Look, on final I have C0 and byte 29 empty when I try to put 05 on byte 29 it gives me error. Byte 29 is empty for me since all time.
Best Regards,
Chirag Geiantilal
Old 11-23-2017, 05:07 PM   #79
Go onto VCDS Rosstech forum & post question there, but all HW, SW etc is completely different to mine...
It may not accept the coding...
Old 11-23-2017, 05:20 PM   #80
cgentil
cgentil's Avatar
Drives: Golf 7
You had byte 29 empty or it had something?
Best Regards,
Chirag Geiantilal
Old 11-23-2017, 05:29 PM   #81
I had byte 29 with a code can't remember what....but not empty...
Old 12-27-2017, 07:38 AM   #82
Hotwire
Drives: 2017 GSW Highline
Hello, 2017 GSW High line with ALL THE GOODIES. I'm looking to update to the ECS/ASR and Mode select buttons on one sidd, amd add the TPMS button ton the other. Iv already ordered the switches and wiring. I'm hoping to get this wrapprd up over a weekend. This tutorial is great but I'm looking for a little more on the TPMS and Mode buttons. Is the mode select an added module? Software?
Hotwire is offline   Reply With Quote
Old 12-27-2017, 11:12 AM   #83
MODE was standard in UK, so not done, but info is in a thread in this DIY section of forum..
TPMS switch I did a how to guide here:-
http://www.golfmk7.com/forums/showthread.php?t=26020
Old 12-31-2017, 08:31 PM   #84
jedadiah
Drives: '15 Golf TDI S
My North American Golf TDI S doesn't have a 5th pin in the T17d housing, so I'll need to run a wire directly from my switch to the ABS unit. Does anyone know what the VW terminal that goes into the ABS connector is? MQS? MCON? Micro Timer? and if so then what wire gauge? Buying the terminals is way cheaper than buying repair wires.
Heres the best page I've ever found for identifying pins https://www.a4-freunde.com/showwiki....s+dazu+gehoert
jedadiah is offline   Reply With Quote
Old 01-16-2018, 07:22 PM   #85
jedadiah
Or if you know what the repair wire part number is, I can figure out the terminal.
