Old 04-18-2015, 04:49 PM   #18
kurhaa
Drives: VW Golf 7 TSI Highline 140 hk ACT DSG
Thanks golfdave for your quick reply.
My VCDS version is the latest Ross-Teck, Version 14.10.2 and it works just fine. When I get to 03-ABS so it says version 1.0.6.13. I installed again to be sure and the same screen comes up. I tried to enter code in Byte 29 but VCDS will not approve this. Also took a copy of the configuration and added 09 during New coding but VCDS not approve these changes.
Do I need to activate the button in the system?
I really want to get to the same as you and need help.
[IMG][/IMG]
kurhaa is offline   Reply With Quote
Old 04-18-2015, 08:22 PM   #19
This is my module with the Byte 29 highlighted, sometimes VCDS can not force the change using the short code (in this case 09), so you have to input the long Binary code in the Binary box. So here is mine, so in your Byte 29 Binary box try entering 00001001 which is the same as mine.
My Build:- Click Here
Old 04-19-2015, 02:28 PM   #20
dr_mat
dr_mat's Avatar
Drives: Golf Mk7 1.4 TSi Estate
Awesome write up. I would bet dealers are looking at this enviously, I would imagine it's way way better than the factory tech specs..
Cars:
Golf mk7 1.4 TSi 122 Estate
Corrado VR6
Life:
Computers and stuff
dr_mat is offline   Reply With Quote
Old 04-19-2015, 09:41 PM   #21
kurhaa
Trying to add 00001001 directly in Binary box but I'm not allowed to store in VCDS. I also made an attempt to reset VCDS to 12.12 version but when I got interphase problem and must surely manipulate USB driver. I will be traveling for a few days this week so I'll start again on Saturday.
Really appreciate the help i get golfdave and look forward to solve the challenge and button to correct configuration.
Old 06-05-2015, 05:33 PM   #22
*CM*
Drives: Golf
great topic! Thank you
*CM* is offline   Reply With Quote
Old 08-05-2015, 04:29 AM   #23
Extreme VW
Drives: 2015 vw gsw tdi
Thanks for the share and hard work
Extreme VW is offline   Reply With Quote
Old 08-18-2015, 04:02 PM   #24
No Problems! Glad to get the information out there!!
Old 12-09-2015, 05:58 AM   #25
Felipesalomao
Drives: Golf 7
Hi, i will buy this switch.. But I also would like to retrofit drive profiles.. My car is German golf 7 1.4 tsi highline.. Do you know if it's possible? I think most difficult change would be vcds settings.. Thank you
Felipesalomao is offline   Reply With Quote
Old 02-25-2016, 04:50 AM   #26
Ursus americanus
Ursus americanus's Avatar
Drives: 2016dsgPP3drSEdccLP
I'm looking to integrate my already hard wired radar detector's mute button into one of the console buttons. The process will be nearly identical to DV52's thread for a garage door opener but I would like to utilize the "eco start/stop" location on the left side row. Does anyone know if that is possible, meaning is the economy switch hard wired to earth, like the park assist and parking aid on the right side and unusable for my purposes, or is the eco switch floating like tire set?
Ursus americanus is offline   Reply With Quote
Old 02-26-2016, 07:01 AM   #27
rickgram
Drives: Golf TDI
A little unrelated to the ESC button, but where do you find the info on these pin outs?
Sent from my Nexus 6P using Tapatalk
rickgram is offline   Reply With Quote
Old 03-05-2016, 09:43 PM   #28
I got the info from forum member DV52 who has access to Erwin. I have a friendly parts guy so I can get stuff that way also, but if you want loads of info then Erwin pay & use download in one day all the info you may need.
Old 03-07-2016, 10:48 AM   #29
Canx
Drives: Golf MK7 1.4TSI TL 122PS RHD
The ESC OFF Button has yellow light? My only white
Canx is offline   Reply With Quote
Old 03-07-2016, 10:43 PM   #30
White when back light, turns to amber when you press it to deactivate the ESC I think?..
Hang on you got me confused now!
Old 03-08-2016, 10:26 AM   #31
Canx
I long press and a short press no amber light ...
But the function is available~
Old 03-08-2016, 04:16 PM   #32
Double checked with manual ook also, no amber light as the button can do short press & long press. The simple ones which do light up amber are active/deactivate functions...
Old 03-24-2016, 11:25 AM   #33
x-father
Drives: Golf 7
Hello. I have done similar solution. Radar detector button conected to left panel.
I bought new leftp panel. Original panel with start/stop panel a swapped with new one with mode + start stop button.
Here is schema of panel, and connector.
x-father is offline   Reply With Quote
Old 03-26-2016, 12:32 AM   #34
Ursus americanus
Thanks, do you know the type/ohm of the two resistors before the "stop/start active" led?
