Old 07-17-2018, 03:28 AM   #1
People909
Drives: 2016 GTI
eurodyne logs.
https://datazap.me/u/people9091724/l...&data=1&mark=9
https://datazap.me/u/people9091724/log?log=0&data=1
hoping that I did this right. how do these look?
People909 is offline   Reply With Quote
Old 07-17-2018, 03:29 AM   #2
Wrath And Tears
Drives: 17 Sport DSG
Originally Posted by People909 View Post
DUDE!!!!! You found the proper website. That's the one I was looking for, but couldn't find. Your google-fu is improving! Now let me look at the logs.
Since I don't know what you want from the logs. It looks like you are making full boost until the turbo runs out of juice.
Cough, perhaps if you posted in the ED thread, you might get some more info, cough cough cough cough cough.
Eurodyne Thread
Save the Drama for Your Llama
Wrath And Tears is online now   Reply With Quote
Old 07-17-2018, 04:19 AM   #3
People909
Drives: 2016 GTI
Eurodyne Thread
I just wanted to make sure that everything with the car is running good like timing, I flashed from the 93oct to the 1.5 91 file
Old 07-17-2018, 04:25 AM   #4
Wrath And Tears
Right so post in the ED thread, and all the guys running an ED tune will let you know. That's one of the main reason the thread exists outside of posting recent updates to the tunes.
Old 07-17-2018, 06:46 AM   #5
ChronicSPD
ChronicSPD's Avatar
Drives: 2017 GTI SE PP
You have officially become the most annoying part of this forum.
2017 GTI SE DSG PP
Eurodyne ECU/DSG Tune, Gplus Twintercooler, 034 Cast Downpipe, APR Dogbone Insert
TRMotorsport C4 18x8, Michelin Pilot Sport 4s (245/40/18)
JL Audio 8" MicroSub+, Audio Control LC2i
ChronicSPD is offline   Reply With Quote
Old 07-17-2018, 09:49 AM   #6
ashiun
ashiun's Avatar
Drives: 2015 GTI Autobahn w/ Leather, Tech, Lighting
This dude legit just ignores all comments asking him to be a decent human being and only cares himself/getting easy answers Lol.
Mods plz ban ability to create threads?
2015 Autobahn GTI 6MT Non-PP
5150 Cobb Tuned| IS38 Rev. S & Forge Blanket | K&N Typhoon Intake, BMS TMD, VWR TIP | DEI Titanium Wrapped CTS Turbo catted DP + Custom CBE | CTS Turbo IC | RS7 Beru spark plugs
DIY TTRS Clutch | KW V1 Coilovers | Stoptech Slotted Rotors + HPS 5.0 Pads | 034 Mounts & Insert | Shifter Bracket + Bushings | Fuchs 75w Gear Oil | 17x9 Advanti S1 Storm & 245/45/17 Indy 500
ashiun is offline   Reply With Quote
Old 07-17-2018, 11:23 AM   #7
bobyjane1234
Drives: MK7 GTI DSG
Funny guy, this guy, keeping me entertained thats is certain!
VWR Springs, ST RSB, BFI Stage 1 engine + Transmission mount, HPA Dogbone mount, Rse10 + Pilot sport 4s. CTS Turbo Inlet
bobyjane1234 is offline   Reply With Quote
Old 07-17-2018, 12:23 PM   #8
RoidRage
Drives: Race Car
Do a tank of 87 on the 93 tune
It will help spot any issues.
RoidRage is offline   Reply With Quote
Old 07-17-2018, 12:25 PM   #9
RoidRage
Drives: Race Car
If the mods aren't going to do shit we should just spam the forum with new threads until they fucking do something....
Old 07-17-2018, 08:21 PM   #10
ChronicSPD
ChronicSPD's Avatar
Agreed. I really almost did, but figured I'd be the one to get the ban hammer.
2017 GTI SE DSG PP
Old 07-18-2018, 05:54 AM   #11
Twist
Twist's Avatar
Drives: 2015 GTI SE 6MT - Unicorn Build Date :)
Lol everyone be nice. He is persistent, which means he cares.
People: Your logs look fine, for an OTS tune. Your fuel rail pressure seems good in the higher rpms (which means there's room to go) and boost holds from quite low (which again can be custom'd out). You can pick up a few degrees of timing from E20, especially during the summer and running some lucas oil upper cylinder lubricant.
Looks like a stage one tune.
PM for Aluminum Heat Res. Air Scoops
PM for Obd11 Long Coding Help
Twist is offline   Reply With Quote
Old 07-18-2018, 01:58 PM   #12
People909
Drives: 2016 GTI
It does look normal? Because I've been trying to figure out the torque, on one log, I converted the Nm to ft/lbs and only came up with 285 ft/lbs and 259 hp. Dont make sense to me idk
Old 07-18-2018, 08:35 PM   #13
Twist
Twist's Avatar
It doesn't work like that. Those "real time" power gauges are not accurate and don't work with tunes. For real power figures you would have to be DYNOED no matter what.
Also, I think your ambient temp and charge pressure actual are swapped for some reason in the log.
Old 07-18-2018, 08:46 PM   #14
It's fine.
IAT is in celsius.
Charge Pressure needs to be converted to psi and then subtract atmospheric pressure (14.7)
238*0.145038=34.5-14.7=~20psi
Old 07-18-2018, 09:18 PM   #15
JC_451
Drives: 2017 GTI Sport 6MT
You can get a fair estimate of HP with a calculator if you have a small bit of data on the car.
If you know the trap speed and weight you can at least get an approximation.
https://www.calculator.net/engine-ho...alculator.html
JC_451 is offline   Reply With Quote
