Old 07-13-2018, 01:36 AM   #1
eickhoffj11
Engine Overspeed
Shifted from 6200 rpm in third into 2nd. I think it fully engaged. (Felt like slamming on the brakes). Read my cars codes and it had a code for engine overspeed. No CEL though. Runs good, sounds good. Leave your opinions and experiences with overspeed situations like this.
I couldn't find any threads on this so figured I'd start one. Probably affected the life of my car. I'm on a fresh oil change. Possibly crying myself to sleep.. lol
Sent from my SM-G920V using Tapatalk
eickhoffj11 is offline   Reply With Quote
Old 07-13-2018, 01:39 AM   #2
Get a compression check done.
Old 07-13-2018, 02:01 AM   #3
Sweetjones_29
Drives: 2017 GTI SE DSG
Sounds like you dodged the money shift bullet. If you do need work done not sure if they will cover it for that code.
Sweetjones_29 is offline   Reply With Quote
Old 07-13-2018, 03:49 AM   #4
The Fed's Avatar
Drives: 2016 Golf R
Can you erase the code?
