Old 07-11-2017, 08:32 PM   #18
Gogo GTI
Gogo GTI's Avatar
Drives: 2017 GTI Sport DSG
Damn got excited for nothing.....
Can some genius please figure this out for the GTI?
Gogo GTI is offline   Reply With Quote
Old 07-11-2017, 08:43 PM   #19
NeedSleep
NeedSleep's Avatar
Read the post that TJN shared above. May not be possible without flashing since the code in VCDS for NAR and RoW GTIs (edit: maybe this should say "DSG" instead of just GTIs) is the same, yet the latter has the gear in D & S modes.
Sent from my SM-G930T using Tapatalk
DSG | JB4 | BFI Stage 1 Engine Mount, Transmission Mount, Dogbone Insert | IE Intercooler
NeedSleep is online now   Reply With Quote
Old 07-11-2017, 10:26 PM   #20
jovian
Drives: 2016 GTI
Also see 14 on my DSG, I guess it is for the slush box only as previously stated
jovian is offline   Reply With Quote
Old 07-12-2017, 12:42 AM   #21
Gogo GTI
Gogo GTI's Avatar
Mainly referring to the fact the mod was done on a Sport Wagon.
But pardon the lack of details earlier. Bummed that there's still no coding solution for NAR GTI's. And obviously referring to DSG since this mod isn't necessary...on a manual. And all MK7 GTI automatics... are DSG. Am I missing something?
Old 07-12-2017, 01:18 AM   #22
NeedSleep
NeedSleep's Avatar
Ah there's a slight misunderstanding. The NAR Golf and Sportwagen (and e-golf and Alltrack?) use traditional torque converter style automatics, while our GTI and R have the DSG. The traditional automatic happens to have a setting available on VCDS/OBDeleven in order to get the gear display working on D & S mode, while it seems the DSG does not.
What Don suspects here is that on the DSG, it's a firmware level change (needs a tune/flash like APR): http://www.golfmk7.com/forums/showthread.php?p=477834
Old 07-12-2017, 04:00 AM   #23
nate704
Drives: 2017 R
At least I can see the gears via JB4 Bluetooth kit with my phone. =)
nate704 is offline   Reply With Quote
Old 07-12-2017, 04:26 AM   #24
Bäsemödel
Drives: 15 Golf TSi
done and i love having it! idk if its always right thought... i know that sounds silly but there were a handful of times when I experienced the sound and feeling of a downshift but the number stayed the same...
Build
Helix UUs//deAuto LEDs//Blacked Roof//Maxton Lip//GTI Skirts//RS7 Plugs//IS20//aFe Dry Filter//JB4//OEM Hatch Spoiler//18” Peelers//Magnaflow Catback w/ center exit//CTS Dogbone//GTI PP RSB//Indy 500s//Koni Special Active Shocks//VWR Springs//HELIX Sub//OBD11//OEM Add Ons - adding fogs/footwells is possible!
Bäsemödel is offline   Reply With Quote
Old 07-12-2017, 05:06 AM   #25
Faceman
Drives: 2017 GSW S 4Mo
4Motion Sportwagens and Alltracks have DSGs, whereas regular Sportwagens have traditional automatic transmissions.
Sent from my SM-G935V using Tapatalk
'17 4Motion GSW, IS38, APR Tune, AWE DP, Uni IC, AFE Magnum;12.65@109.54, 1.98 60'
Faceman is offline   Reply With Quote
Old 07-12-2017, 08:10 AM   #26
Gogo GTI
Gogo GTI's Avatar
Gotcha. Thanks for the clarification.
Old 07-13-2017, 01:25 PM   #27
AustinNeal
AustinNeal's Avatar
Drives: golf
thank you for sharing this!
AustinNeal is offline   Reply With Quote
Old 07-20-2017, 05:17 PM   #28
Crudulous
Drives: GTI
Just wanted to say, good answer and research!
Crudulous is online now   Reply With Quote
Old 03-29-2018, 04:12 AM   #29
southpawboston
southpawboston's Avatar
Drives: '17 GSW S
Apparently this mod does not work on all hardware versions of the Aisin TCM.
I'm pretty bummed.
02 Transmission
System description: AISIN AG6 G3
Software number: 09G927158AR
Software version: 3198
Hardware number: 09G927158
Hardware version: 202
ODX name: EV_TCMAQ250031
ODX version: 002009
Long coding: 010200000C000000000000000000000000000000
When I tried long coding, the change was rejected citing unsupported.
Bummer.
OBDeleven coding mods
past VAGs: '69 Type 3 Variant • 1984 GTI • '85 Scirocco Wolfsburg Edition • '86 Scirocco • '86 Audi 4000S
southpawboston is offline   Reply With Quote
Old 07-03-2018, 01:12 AM   #30
southpawboston
Drives: '17 GSW S
I'm pretty bummed.
02 Transmission
ODX version: 002009
Bummer.
UPDATE. I revisited this after months of being really disappointed at not being able to see the gear # next to D/S, so I fired up the ol' OBDeleven and tried again. As before, I got the same error (Error 71 function not available). So I tried switching diagnostic service modes to VW diagnostic mode, and voila! In that mode the change took effect! Results were instantly verified. I am so happy now. This feature should have been provided stock.
Old 07-03-2018, 02:58 AM   #31
tonipepperoni77
tonipepperoni77's Avatar
Drives: 2016 Golf R , '12 z4
Can you post a full walkthrough of what we need to do?
tonipepperoni77 is offline   Reply With Quote
Old 07-03-2018, 03:03 AM   #32
southpawboston
Drives: '17 GSW S
I can, but if you have an R, it won't work.
Old 07-03-2018, 03:19 AM   #33
tonipepperoni77
Ah damn
Old 07-03-2018, 03:38 AM   #34
Gogo GTI
Gogo GTI's Avatar
And not on GTI.
