Old 01-12-2018, 08:53 AM   #52
George Ab
Drives: GTI MK7, BMW E90
Originally Posted by ARi View Post
Has anyone got the coding for the amp latest mib2 amp which has sound settings below the profiles instead of a separate page as I believe this is what I need
Not sure if I am missing something? I responded to your previous request for MIB2 coding in post #41.
George Ab is offline   Reply With Quote
Old 01-12-2018, 10:06 AM   #53
ARi
Drives: Golf 7 GTD
Hi George
Not sure if you are aware but the mib2 units have various codings
I have copied my mates coding which is a mib2 but his differs from mine
His is separate for profiles and individual sound adjustment
Mine has the profile eg authentic. With the picture and if I want to adjust the sound this picture stays there and the sound adjustment is below it
I hope you undersnd whah I’m sayin
Can you confirm yours is the same
Thanks again for your help
ARi is offline   Reply With Quote
Old 01-12-2018, 10:18 PM   #54
sportwagen3
Does anyone know if we can reprogram the voice button on the steering wheel to something else? For example, I would like to activate Google assistant in AA. Any ideas?
sportwagen3 is offline   Reply With Quote
Old 01-12-2018, 10:34 PM   #55
quailallstar
Drives: MK7 Golf Variant R-Line
Same here except I want to make it a mute button. This can be reprogramed on the MK6 platform.
2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8t FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
quailallstar is offline   Reply With Quote
Old 01-13-2018, 12:02 AM   #56
sportwagen3
Nvm. If I long press it, it activates Google assistant. I think the mute function can be programmed through vcds. I'll play around later.
Old 01-13-2018, 01:41 PM   #57
ARi
Drives: Golf 7 GTD
George is that fender coding or dynaudio?
Old 01-16-2018, 11:22 PM   #58
George Ab
Fender, I have a NAR GTI.
Old 01-16-2018, 11:25 PM   #59
George Ab
Great question for the VCDS thread. It does not seem to pertain to MIB1 to MIB2 conversion.
Old 01-27-2018, 12:30 PM   #60
zvonexp
Drives: Golf MK7 Edition 40 R-Line
Hi everyone
I'm upgrading from mib 1 to mib 2.. but it looks that is mib2 unit from passat and now on car i see passat and on clima menu is passat
how i can change that to golf ?
zvonexp is offline   Reply With Quote
Old 01-28-2018, 07:05 AM   #61
sportwagen3
Originally Posted by zvonexp View Post
Hi everyone
You can code it through vcds. Did you save your coding from your MIB1?
Old 01-28-2018, 07:28 AM   #62
George Ab
Hi everyone
This is from memory as I don't have Vag-com up. First byte in coding select Golf (that is were Passat is currently selected); in byte 18 select GTI (that is where sub-model Golf, GTI, Golf R, GTE, etc are), I believe it is 03. This is my coding. Also, as in DIY you should of saved your logs. Compare the two and with long coding helper it will validate what I have said above.
Bold is where model and sub model are contained in code.
027300000000000051220002001808001F0203F40120010002
Old 01-28-2018, 02:55 PM   #63
zvonexp
yeah, i forgot to wrote
i managed to fix that
one more question
if u re using mib2 unit and mib1 dynaudio.. without changing amplifier on unit they working only SW or HW MOD ?
Old 01-29-2018, 04:38 AM   #64
George Ab
one more question
Sorry I can not really help. For North American cars we have the Fender system. Not sure what the differences are between Dynaudio and Fender so I can only speak to the Fender system. For the Fender system I had to replace the amp to the MIB 2.
Old 01-29-2018, 09:18 AM   #65
ARi
Drives: Golf 7 GTD
one more question
What is mib1 dynaudio
I have a mib 2 unit and a mib2 amp
But my subwoofer is producing vocals for some reason
Old 02-13-2018, 02:18 AM   #66
sprinks
Drives: GTI Mk7
Finally got around to making progress on this. Hardest part was definitely wiring the USB wiring to the back of the brain. Got it taken care of tonight though. I did notice my 605H screen has a ROW fitting but NAR connector. Weird, but easy fix.
Sent from my SM-G900T using Tapatalk
P E T R O L P I N T S Enthusiast Inspired Pintglasses
wheelwell & GTI mk7 journal
Old 02-16-2018, 12:48 AM   #67
sprinks
Drives: GTI Mk7
Latest update in my MIB1-> MIB2 blog. :P As mentioned in previous post, installed everything. Officially got CP removed by the extremely helpful team at the dealership. They followed the CP removal and activation key instructions to the T, but the key kept getting rejected. They called VW Tech line and essentially the word is "nein nein nein" trying to add the carplay functionality back. It sounds like this may have been what you experienced George Ab. If that's the case, i will be pursuing the remote-to-poland technique mentioned and would recommend that for others as well.
Old 02-19-2018, 10:18 PM   #68
danjam
danjam's Avatar
Drives: '15 GTI
I got everything to work. Thanks George for this guide. Definitely was helpful. The coding was the main issue as to why 47 was not responding. I was able to code the rearview camera, boot logo, and car image after component protection was removed from the MIB and amp.
Just to clarify, you needed to get CP removed before the controller would recognize 47? I'm having the same issue after install, but Im waiting for my appt at the dealer to do CP/FECs.
Also, who did your remote coding in case I need to go that route... however I already have my legit app-connect fec codes
Sent from my Nexus 5X using Tapatalk
NCE MRMT: '15 GTI CSG SE PP LP 6MT
danjam is offline   Reply With Quote
