Old 04-14-2017, 03:06 PM   #18
Nitsrik1976
Drives: MK7 R
Originally Posted by o_a_ravi View Post
Played around with the 5F Infotainement Controller Adaptations and was able to get it work.
Below is the steps to enable blocked settings menu items for Car (General Settings), Media, Phone and Radio
1. From VCDS, select Controller Module 5F-Information Electr.,
2. Enter Security Login code = 20103
3. Under Adaptions, Query for the channels listed below and set the value = NON_BLOCKED (Blocked means, settings not available in motion), for each of them.
IDE11502-ENG127601-Locked menu contents-FB_CAR_0
IDE11502-ENG127612-Locked menu contents-FB_CAR_11
IDE11502-ENG127613-Locked menu contents-FB_CAR_12
IDE11502-ENG127603-Locked menu contents-FB_CAR_2
IDE11502-ENG127604-Locked menu contents-FB_CAR_3
IDE11502-ENG127608-Locked menu contents-FB_CAR_7
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7
Worked for, try and let me know if it worked for you.
Thanks,
Ravi.
Please tell me what unlocking all of those does. Which ones allow video in motion specifically please
Nitsrik1976 is offline   Reply With Quote
Old 04-14-2017, 03:55 PM   #19
Vincenz
Drives: 2017 GTI Sport dsg
I tried this via obd11 and it didn't work for me. Tried turning the system on and off, turned car on and off. No luck. I can live with it I guess. Technically it is safer.
Vincenz is offline   Reply With Quote
Old 05-18-2017, 12:14 AM   #20
Aonarch
Drives: All Track
Thanks,
Ravi.
Thank you!
Aonarch is offline   Reply With Quote
Old 07-06-2017, 04:48 PM   #21
need2boat
Drives: Golf Alltrack
I've got a 2017 Alltrack and most of the mods I've found on the site have worked for fine.
I'm trying to find a way to better access the media settings when I"m using bluetooth. I've made the above changes but I still can't get access this grayed out "remove Safely" and select device.
I can't seem to access my BT audio when I'm driving? which is strange.
[IMG]IMG_4836 by need2boat, on Flickr[/IMG]
need2boat is offline   Reply With Quote
Old 07-13-2017, 11:00 PM   #22
Apw36
Drives: 2017 GTI
Maybe someone else will correct me, or I am misunderstanding. If you want to play BT music, you should be able to access it in to the menu before the settings menu. There is a source option. As for this grayed out "Remove safely," I believe this is if you have a media SD card in the additional SD card slot. This is when you want to safely eject the media and stop the system from reading the SD card.
Apw36 is offline   Reply With Quote
Old 07-17-2017, 02:00 AM   #23
mr wrong
Thanks,
Ravi.
Will this work to disable the touch limit when using Android Auto?
mr wrong is offline   Reply With Quote
Old 07-17-2017, 05:23 AM   #24
CDavis7M
Drives: None
I unblocked everything I could and I still get some locks in Android Auto. Like when browsing Spotify, but only when I am 4 menus deep into browsing stations. And even then I can still get it to sometimes if I'm quick.
CDavis7M is offline   Reply With Quote
Old 07-17-2017, 11:44 AM   #25
NCR-R
Drives: 2017 Golf R
Originally Posted by The Fed View Post
Mine works while moving.
So does mine and I never made any changes... guess I got lucky for once!
NCR-R is offline   Reply With Quote
Old 02-27-2018, 02:46 PM   #26
sprinks
Drives: GTI Mk7
Just did the changes via obd11. Worked flawless. Thanks for figuring this out. P.s. my model is the revA mib2. I imagine this was a 17MY revision.
Sent from my SM-G900T using Tapatalk
P E T R O L P I N T S Enthusiast Inspired Pintglasses
wheelwell & GTI mk7 journal
Old 07-13-2018, 06:22 PM   #27
Jovicente
Drives: MK7
This coding allows video in motion on my18?
Jovicente is offline   Reply With Quote
Old 07-13-2018, 08:06 PM   #28
dman918
Drives: 2018 Golf R
Id like to know as well. 2018 Golf R. Thanks.
dman918 is offline   Reply With Quote
Old 01-13-2019, 06:48 PM   #29
steveaustin
Drives: 2018 GTI Autobahn
I can't get this to work on my 2018 GTI. Says function not available. Cleared app data and cache but won't let me change these settings. Anyone know a fix?
steveaustin is offline   Reply With Quote
Old 01-13-2019, 07:22 PM   #30
southpawboston
southpawboston's Avatar
Drives: '17 GSW S
If your'e using OBDeleven, this seems to be a common problem. Oftentimes before I set out to make adaptation changes I will change diagnostic service modes on the main screen of the module I want to perform the changes to. Go to Change Service --> select VW Diagnostic Service Mode. Then go to Adaptation or Long Coding to make your changes. This seems to eliminate a lot of the "function not available" errors I would get. Not all, but many.
OBDeleven coding mods
past VAGs: '69 Type 3 Variant 1984 GTI '85 Scirocco Wolfsburg Edition '86 Scirocco '86 Audi 4000S
southpawboston is offline   Reply With Quote
Old 01-14-2019, 08:15 PM   #31
steveaustin
Great, thanks for the tip. Do you recommend changing all the items to unblocked in this area? I see different people posting things to say change all or only change a few. Would unblocking all cause any harm?
Old 01-20-2019, 05:08 AM   #32
steveaustin
I believe there is a separate nhtsa menu in 5F that affects these but have not tested. I see iPhone and Adroid blocks.
Old 01-20-2019, 07:25 AM   #33
Navi
Drives: 2017 GTI SE 4DR 6SPD
I'm going to try this tomorrow... will report back
AWE, Recaro, Forge, Unitronic, SRE, IE, 034, Bilstein, HR, Super Pro, Tyrolsport, AP Racing, Enkei, Neuspeed, Rieger, Rennline, 42DD
Instagram: https://www.instagram.com/gti_rs/?hl=en
Build thread: https://www.golfmk7.com/forums/showthread.php?t=47754
Navi is offline   Reply With Quote
Old 01-21-2019, 03:36 AM   #34
steveaustin
I tried this and still cannot overrride blocked to unblocked using VW Diag Service Mode. Maybe there's something with the 2018s that prevents these from being tweaked without some other change. Anyone with a 2018 able to do this? I don't have the car running just accessory mode on. Does the headunit need to be off? I have successfully coded my power folding mirrors so it's not like i don't know how to use OBDEleven.
