More robust turbo vs breakage
XM_Rocks
Austin, TX
Have to find what they use to determine payment.
Plus as I read it you will have to be denied warranty work at the dealer first then have it moved to another shop.
Seems sill and a big hassle, if you’re a responsible person and tuned you shouldn’t even attempt going to the dealer for warranty work on the motor/driveline when tuned.
Just find a good independent shop and save money.
If your worried about repair costs and warranty loss, sit on the sidelines.
emanon
SoCal
Shaft breaks.
Shitty.
Ill have to see if i can get my hands on a broken one and see what the issue is. Should be easy to determine if its twisting the shaft or fracturing. Vibration should look very different from being over torqued.
If it's a torque issue then an IS38 that isnt pushed as hard should be much more reliable. If its just a bad shaft (material spec) or balance issue it wont make much difference.
Maybe precision will over a ball bearing direct replacement turbo, but it wont be cheap.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Oldschoolmk7
Yonder
First determine what overall power level do you want? Where in rpm range is that power and torque important to you? If 300-335/360-385 wheel is not enough then of course look at a bigger turbo. Go for ride in a good running stage 2 APR GTI and see how that feels first. Just my 2 cents.
marc5800
Ottawa
This is good advice
320-330whp is more than fast enough for my liking. Atleast for most public roads. The missing component is that whp number / speed done with a reliable source (turbo)
Hoon
Rhode Island
What I wanted to know here is whether any of the turbo options out there are less likely to break than the IS20 or IS38?
The only options I would choose at this time, with reliability being the priority, are Boss or DBV2. Both are $3K
Rafiki76
Los Angeles
MKVII GTI
One idea I had was to have my turbo rebalanced when I go APR Stage 2 LO. Would that help at all?
Wrath And Tears
Azusa, CA
17 Sport, 99 E36
No one knows.
Exactly, no one knows for sure what causes the shaft to break, but if it was due to an unbalanced turbo, I assume more would be blowing up when they reach a certain PSI with a tune. That doesn't mean it couldn't help prolong the life of the turbo. That being said it might be more worth your money to buy a different turbo.
Rafiki76
Los Angeles
MKVII GTI
No one knows.
Ok thanks for the advice.
psychonosspaz
PNW
