mw1978
Europe
So I got another datalogs and on my eye it’s good but who knows...
I decided to use absolute map because is stronger the previous additive map.
FOL 55
Boost shift redux 90
6 cyl 1
1500—16
2000—18
2500—20
3000—21
3500—23
4000—25
4500—24
5000—23
5500—22
6000—20
6500—19
7000—18
https://datazap.me/u/nicram1978/absolutna-2-3-4-5?log=0&data=1-2-3-4-11-12-18-25-26-27-28
https://datazap.me/u/nicram1978/log-1531262539?log=0&data=1-2-3-4-11-14-18-25-26-27-28
https://datazap.me/u/nicram1978/log-1531262675?log=0&data=1-2-3-4-11-14-18
Diggs24
de plains! de plains!
2015 GTI
FOL 55
6 cyl 1
1500—16
2000—18
2500—20
3000—21
3500—23
4000—25
4500—24
5000—23
5500—22
6000—20
6500—19
7000—18
Looks good. Keep an eye on trims and AFR with that kind of load though.
Diggs24
2015 GTI
Anyone have a picture of their map 6 user settings? Switching tn from 2. Obviously a lot of stuff on here.
Fuel Open Loop 50
Boost Safety 26
Fuel Bias all 100
Need to know mod list and fuel or see a log to give map6 recommendation (also M6 or DSG).
mk7_bk
Hello, recently installed jb4_rev3.0 . Have the car on map2. I read in here somewhere to log that then put them up here so I can learned how the car runs and make a good map6 tune. Some (maybe) important info: 17 gti, running 93, mods: DP, intake, res delete, IS20, GFB DV+. (Had a passenger in car logging) (Edit, need to run some logs when its an open road )
Here is a run 2500 -6k (3rd whole time)
https://datazap.me/u/mk7bk/run-2?log=0&data=1-4
Here is a run (3rd - 4th)
https://datazap.me/u/mk7bk/good-run?log=0&data=1-4
Not sure what I need to look at or look for, gotta do more research about that here. Any comments I'll be sure to read and reply.
Thanks
Sorry about the bumps need to look at this for later
rodolfo
Brazil
got my jb4 used yesterday, so no George's support..
I'll install a DP tomorrow, so made some pulls today on maps 0,1 and 2 for comparison (made 2 logs for each map).
Never used jb4 before or anything like that.. but for me seens like map2 AFR is wierd. Should I set Fuel Bias 100 to all? (it's 0 right now)
map2 - https://datazap.me/u/rodolfo88/map2?log=0&data=1-4
map1 - https://datazap.me/u/rodolfo88/map1?log=0&data=1-4
map0 - https://datazap.me/u/rodolfo88/map-0?log=0&data=1-4
oh, it's a GTI DSG, with regular gas (i'm from Brazil, here the regular gas have 27% ethanol on it) . Pulls were in 3rd gear.
I did not run map6 yet, but for what I see there, it is too high (26 psi max)
mk7_bk
Ok, switched to map 6. Stuff: 93 octance, dp, intake, turbo is20,
settings
Fuel open loop 50, Bias all 100, boost failsafe 26,
RPM
1500 2
2000 3
2500 4
3000 4.5
3500 5
4000 5
4500 6
5000 7
5500 7
6000 7
6500 6.5
7000 6.0
Logs:
Run 1
https://datazap.me/u/mk7bk/run-1-map-6?log=0&data=1-2-4
Run 2
https://datazap.me/u/mk7bk/better-run-2-map-6?log=0&data=1-2-4
Thoughts: From what I see it looks ok. Total beginner with looking at these logs. If anything looks funny let me know :)
Side Note, Run 1 shift from 3-4 wasn't great shift knob was a little loose. Had a odd pop noise during that time 2. Run 2 felt great while doing it.
Thanks for reading.
psychonosspaz
PNW
So did my first log in insane heat for the PNW and my GTI Jake FMIC....has quite a bit of timing pull across a few cylinders....wondering if I should switch to absolute in the heat, but was never impressed with how it felt....see my log below, again 90 degrees OAT, 3rd gear, the IC appears to be doing its job as this was my 3rd pull in a row and came within 6 degrees of OAT....if anyone is running a good absolute map or has suggestions please let me know....car felt pretty strong in the pull
arob157
Post the actual log to datazap.me
Or attach the .CSV file. That would be a huge help.
