Steering Tilt Lever mod
IK/GTI
GTA
I was tired of getting jabbed in that tender spot behind the left knee cap, so did a number on the Steering Tilt Lever ... lol
Other than not realizing the part was not solid, it turned out as I had hoped. Will need to get some buffing compound to clean it up a bit. Might profile it a some more to even out the slots. :cool:
Finglonga
Hollow for weight saving.;) Looks good like that IMO, better than the stock.
IK/GTI
GTA
Faceman
Long Island
'17 GSW 4Mo
#tallpeopleproblems? Or are you guys sitting too close? At 5'9", I've never hit that piece.
IK/GTI
GTA
There are likely a lot of factors that might make this an issue. I only know that in my preferred setup, it was a nuisance. Was not about to adjust my seating position to accommodate a lever if there was an option. Plus, got to work on my car :D
eurospek
Just finished watching Fast&Fu
Chicago
I’m 6’4 and never made contact with this lever. YRMV.
southpawboston
Somerville, MA
Give the slots some red paint fill... you know, because GTI
eurospek
Chicago
What did you use to trim?
IK/GTI
GTA
IK/GTI
GTA
Just a grinding wheel for my Drumel was all I had at hand. Then 60 grit sandpaper with sanding block to clean up the cut, then down to 400. Will need to get something finer to finish it off.
