To echo the other thread, keep in mind I'm running 27+ psi, and on the single gear pull I went from 2200 RPM to nearly fuel cutoff (6800 RPM). Seems like many of the logs out there start after 3K and end before 6K. I wanted to get the full picture, even if this is not how I normally drive when I push it hard.
Obviously you're well versed in the subject, and trust me I would love to be in the position to drop coin on one of your coolers. They're awesome and I can totally appreciate the work you do. But keep in mind this is just a budget cooler which shows a good improvement over a stock (or R) cooler. Basically, it's for those who are looking for an effective yet affordable upgrade, and/or for those who don't want to go to the trouble of replacing a stock location cooler.
Unfortunately when I bought the car, I didn't know much better regarding the R cooler, and there were none of the cheaper aftermarket solutions at the time. Had I known they were upcoming, I'd have waited
This time around, I really was not motivated to pull everything apart a 2nd time to replace the R cooler with a Magic/Majesty or similar.
