Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Regional Forums > AUSTRALIA
Old 02-13-2018, 12:12 PM   #1
Talbs
Akrapovic titanium system availability in Aust?
Anyone heard about an Aust source or been able to import for a Mk7 R? Also keen hear from anyone who has one fitted to an APR downpipe.
Sent from my SM-G930F using Tapatalk
Talbs is offline   Reply With Quote
Old 05-04-2018, 04:46 PM   #2
The Fed's Avatar
Drives: 2016 Golf R
Unless things have changed, the only way to get one is factory installed on the car. Even if it were sold separately it would cost thousands, probably $3,000.
