FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > Golf R Discussions
Reply
Thread Tools Display Modes
Old 09-04-2019, 11:27 PM   #18
GolfR2015
Member
Drives: 2015 Golf R & 2014 GTI & 1970 BMW 2002
Quote:
Originally Posted by FRDRICE View Post
Nice. The one lap I timed when you didn't get any traffic was a around a 1:44 which is pretty good around there. What tires and suspension are you running?
Appreciate the timing,
Bridgestone RE-71R
VWR Springs
GolfR2015 is offline   Reply With Quote
Old 09-05-2019, 12:21 AM   #19
ChrisAttebery
Junior Member
Drives: 2011 GTI
These will keep your seat belt from coming loose. They are cheap too.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Quote:
Originally Posted by GolfR2015 View Post
Thanks Cliff, that's all I needed to hear. I will be servicing mine soon. Do you have a harness/bars or seats in your R? You may have noticed in the video that I keep tugging on my belt to keep myself in the chair! Appreciate it...
ChrisAttebery is offline   Reply With Quote
Old 09-05-2019, 01:25 AM   #20
M3bs
Senior Member
Drives: 95 S54 M3 track toy, 2016 LSG Golf R
For reference on Firestones, G-Loc pads. https://youtu.be/JgSN0X0xGrs
M3bs is offline   Reply With Quote
Old 09-05-2019, 03:18 PM   #21
GolfR2015
Member
Quote:
Appreciate it.. I will check them out.
Old 09-05-2019, 10:46 PM   #22
cbell3186
Member
Drives: 2017 Golf R DSG DAP
Quote:
Originally Posted by Cliff View Post
No. One of the things Griffin will be doing next week is machining a bit of the shoulder of the front seat belt bolts down to a 12mm diameter and then install the tails for the Schroth quickfit harnesses that I have. A guy over on vortex did that with his car recently, and this approach didn't occur to me when I tried to install these harnesses 4 years ago when the car was new. The Schroth tails fit over a 12mm bolt, but the front bolts have a 14mm unthreaded shoulder over which the seatbelt end slides. Griffin will remove enough of that to accommodate the tails while still allowing the bolts to be tightened all the way down. The rear bolts don't have this issue.
Hey Cliff,
Forgive me if I am off here or out of the loop or something, but the pic you posted with the desired machining at the smooth part near the head, why would you remove material there and not open the hole up where that bolt goes into? My concern is if you get in an accident and that smooth part (where material is already removed from the interior to accommodate the tripple square) the lack of remaining material will just shear the bolt off if the impact is bad enough. Your safety seems to be more at risk with machining the bolt? No?
cbell3186 is offline   Reply With Quote
Old 09-06-2019, 12:46 AM   #23
Cliff
Senior Member
Cliff's Avatar
Drives: 2015 Golf R with DSG, DCC & Nav
Quote:
Originally Posted by cbell3186 View Post
Hey Cliff,
The Schroth tails will go inside the seatbelt, so we will reduce in diameter to 12mm a section approximately 4.5-5mm wide of the shoulder next to the threaded section. Since the threaded section is 12mm in diameter, as are the rear seat belt bolts, VW must have determined that 12mm of steel bolt is enough to anchor the seatbelts.
__________________
Photo: Link to Photo -|- Build Thread
Cliff is offline   Reply With Quote
Old 09-06-2019, 01:27 AM   #24
M3bs
Senior Member
This you?
Old 09-06-2019, 01:36 AM   #25
Navi
Senior Member
Drives: 2017 GTI SE 4DR 6SPD
This is interesting. Schroth was telling me about this fitment issue with their harnesses and the MK7. I didn't know what they meant but now I understand from what you mentioned. I ended up getting my harness to fit a different way, but that looks like a good idea also. I went with ARP bolts.
__________________
AWE, Recaro, Forge, Unitronic, SRE, IE, 034, Bilstein, HR, Super Pro, Tyrolsport, AP Racing, Enkei, Neuspeed, Rieger, Rennline, 42DD
Instagram: https://www.instagram.com/gti_rs/?hl=en
Build thread: https://www.golfmk7.com/forums/showthread.php?t=47754
Navi is offline   Reply With Quote
Old 09-06-2019, 01:59 AM   #26
Cliff
Senior Member
Cliff's Avatar
Quote:
Can you expand on that? (not that I have time to react - the car is going in to Griffin on Monday)
And I didn't really respond to the OP's question as fully as it deserved. I am in the camp that says you either work with the factory safety systems, or you completely replace them. Schroth's quickfit products offer a nice integration with factory safety systems while adding improved driver restraint, and support for FHR devices that aren't Simpson Hybrid S devices if you opt for the quickfit pro harnesses.
Going with a harness bar and separate harness leaves all the factory safety equipment in place, but removes key sensor inputs the factory safety equipment would use to protect the driver in a crash. So the airbags and other safety equipment may deploy in a crash. Or maybe not. That doesn't strike me as a great approach.
__________________
Old 09-06-2019, 04:28 AM   #27
Navi
Senior Member
Griffin is good for that race stuff.. harnesses/seats etc. I'm sure they'll come up with a good option. I'll have to take pics of my set up. I'm running a harness bar and I replaced that lower screw with a ARP 7/16-20 1 inch bolt to hold the lower bracket more solidly. Then I used an ARP 3/8-16 2.25 inch to bolt the harness bar support bar and lower oem seat belt to the bracket to retain use of oem seatbelt. I can actually use the oem seatbelt even when it is not mounted to the lower bracket, but it would be lacking the pivot point.
Easier to explain with pictures. I'll take some when I get a chance. Might be a bit though, bc I'm getting the bar powder coated.
__________________
Old 09-06-2019, 09:16 AM   #28
Cliff
Senior Member
Cliff's Avatar
No worries, I scanned your build thread and it looks like you're using Tyrolsport's harness bar. Love the seats (Griffin is a Recaro dealer and apparently offers discounts, but not this year...I'll be giving them more than 10 bills next week and that's enough damage for now).
__________________
Old 09-06-2019, 11:31 AM   #29
GolfR2015
Member
Yes!
Old 09-06-2019, 11:32 AM   #30
GolfR2015
Member
This you?
Yes, that's me!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
