Cliff
- San Francisco Bay Area
- 2015 Cayman GTS
Thanks Cliff, that's all I needed to hear. I will be servicing mine soon. Do you have a harness/bars or seats in your R? You may have noticed in the video that I keep tugging on my belt to keep myself in the chair! Appreciate it...
No. One of the things Griffin will be doing next week is machining a bit of the shoulder of the front seat belt bolts down to a 12mm diameter and then install the tails for the Schroth quickfit harnesses that I have. A guy over on vortex did that with his car recently, and this approach didn't occur to me when I tried to install these harnesses 4 years ago when the car was new. The Schroth tails fit over a 12mm bolt, but the front bolts have a 14mm unthreaded shoulder over which the seatbelt end slides. Griffin will remove enough of that to accommodate the tails while still allowing the bolts to be tightened all the way down. The rear bolts don't have this issue.
