Backtrack2015
- Texas
I pulled the passenger-side windshield cowl and unplugged the two-wire connection to the soundaktor itself (car is a 7.5 R). This was much easier than unplugging the multi-wire connector below the soundaktor that is the target of most videos. I assume the multi-wire connector is to the amp/controller below the soundaktor and what I effectively did was kill the final connection to the "speaker" or "active-element" that vibrates the windshield.
Anyone see any real issue with this? Is there any reason for me to pull the multi-wire connector instead? Thank you.
Edit to add: I just found a thread on another forum where several people had done the same with no ill effects. I think it should be fine.
