r-gazmic
- Colorado Springs
Is it possible you switched the numbers on the theoretical top speed? I thought the MT was geared taller, at least in 5th and 6th...the reason for the slightly better EPA numbers. My MT Mk7 shows 2000 rpm at 60 mph in 6th, much taller than the DSG in my Mk6. Thanks for posting.
On the R there are different final drive ratios for gears 1-4 and gears 5&6: http://media.vw.com/doc/1342/16639762254eb40c8bd4a5.pdf
Here's the same for the GTI: http://media.vw.com/doc/1729/759942923566f0c5861a54.pdf
I'm not sure if the previous poster took that into account when making those calculations, if not the numbers for 5th and 6th would change.
