rafycotto
25psi.Raffy, how much boost are you able to run on our crap gas?
https://datazap.me/u/rafycotto
Sent from my 2PZC5 using Tapatalk
If u already has Ed tune, it is only 3 credits for maestro ($187)
Yes, no meth. Pure 91oct from Shell.I looked at your first 25/91 assuming no meth there?
You are 479 and I barely touch 400 torque and have -3 where as I had -4.5-5 at 91/25. It’s killing me to know what’s up.
Here is 89/27 for all the boost and little timing. I think something is up still only make 23.5 psi same at 23, 25, 26 setting.
Timing looks better. Check out 5148 with the torque spike?
45 degrees ambient and still can't make over 400 torque. Wastegate was at 60 when it should be maxed out at 80? Correct me if I am wrong.
https://datazap.me/u/phsycomatt89/8927-91-octane?log=0&data=1-5-15-16-17-18-19-22&solo=23&mark=36
Elevation is 2389 I have access to ACN91. E85 is around here but I really don’t want to have to rely on always finding e85 if I travel.
The road was decently smooth and that was something I thought of with ghost knock.
89 and 91 timing was similar boost was identical. Even though the slider for boost was way different.
Go water/meth it helps a lot with heat and shit gas. I have the same garbage gas as you in Yuma arizonaThat’s great info, thanks. I asked a master tech friend who is mod friendly and he says VW didn’t design our cars for ethanol use. I’ll have this car for awhile so I really don’t want to go through fuel components anytime soon. I know a lot of people have used it for years but I’m torn. Here’s one I took previous at 27/91.
https://datazap.me/u/phsycomatt89/is38-26-psi-91oct?log=0&data=1&zoom=0-53
