FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > DIY Guides and Discussions
Reply
Thread Tools Display Modes
Old 01-04-2018, 11:13 PM   #35
ARi
Member
Drives: Golf 7 GTD
Retrofitted dynaudio mib2
The sound is not perfect and the sub is producing sound and bass rather then just bass
Is this coding?
ARi is offline   Reply With Quote
Old 01-04-2018, 11:34 PM   #36
XoneDB4
Senior Member
XoneDB4's Avatar
Drives: Mk7.5 GTI PP DSG
Is this coding?
I’m no car audio expert but I’d have thought a low pass filter in line to the sub would be the simplest solution.
XoneDB4 is offline   Reply With Quote
Old 01-05-2018, 06:41 AM   #37
George Ab
Senior Member
Drives: GTI MK7, BMW E90
Quote:
Originally Posted by sportwagen3 View Post
Any instructions on how to route the wire for the usb/aux? Did you remove panels on the passenger side or did you remove the glove box? If so, how did you do it?
From the article: "I removed the side panel and took a bicycle cable shroud, these work great for fishing cabling. If you don’t have one just go to your local bicycle ship and ask for one they have replaced. House wiring cable is also decent, a clothes hanger is likely not long enough. After removing side panel I started from there and went half way through dash, reached up and pulled down to cubby. Now I could tape USB/Aux yellow and green connectors to my shroud and fish up harness to infotainment unit. Green connector will slide into large connector."
George Ab is offline   Reply With Quote
Old 01-05-2018, 06:54 AM   #38
George Ab
Senior Member
Is this coding?
Not sure what this has to do with a MIB1 to MIB2 conversion.
That said, you may want to check byte 04 and 11 to see if they are set up for external amp (Dynaudio - Fender in US). Not sure if it relates to your Dynaudio conversion.
From article:
"Since your unit is likely from salvage it is already coded with adaptations all sorted. However, you should check a couple of things in the 5F module. Check bytes 4 and 11 if you have a Fender System as the donor unit may not have come from an external amp unit. In my case I did have to change the values to the original values of byte 4 to 00 and byte 11 to 02. Also verify byte 19 is set for USB iPhone fully functionality."
Also, I thought I saw something about Dyanaudio conversion on the Ross-Tech forum.
Old 01-06-2018, 01:42 PM   #39
ARi
Member
Drives: Golf 7 GTD
Hi
Thanks for your help and these options have been checked
I think the amp itself needs coding
Can anyone share the coding for a mib2 amp
47 - sound system long coding
As I have a fault saying control module not coded
Old 01-08-2018, 01:17 PM   #40
sportwagen3
Member
I'm getting no response from 47 in VCDS for the MIB 2 amp. Anyone know how I can fix this?
sportwagen3 is offline   Reply With Quote
Old 01-09-2018, 06:41 AM   #41
George Ab
Senior Member
Hi
Code:
         ;SW:5Q0-035-456   HW:5Q0-035-456 ---  Sound System
      ;Component:MIB2_lite_amp H20 0130    Coding:2200000000AAAAAA000000000000
      ;EV_AMPMst12C1Gen2ALPI   1003   EV_AMPMst12C1Gen2ALPI.rod
      ;Tuesday   23   May   2017   12:00:12:51554
      ;VCDS Version: Release 17.1.3 (x64)  Data version: 20170320 DS267.7
      ;VCID: 6DFF3AE7BC589C2932-8038
      IDE10493-MAS03001-Electrical test 2 of   loudspeakers-Mode   automatic
      IDE10493-ENG117360-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency   19000 Hz
      IDE10493-ENG117361-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume   60
      IDE10493-ENG117378-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency   19000 Hz
      IDE10493-ENG117379-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume   60
      IDE10493-ENG117380-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency   19000 Hz
      IDE10493-ENG117381-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume   60
      IDE10493-ENG117382-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency   19000 Hz
      IDE10493-ENG117383-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume   60
      IDE10493-ENG117384-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency   19000 Hz
      IDE10493-ENG117385-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume   60
      IDE10493-ENG117386-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency   19000 Hz
      IDE10493-ENG117387-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume   60
      IDE10493-ENG117388-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency   19000 Hz
      IDE10493-ENG117389-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume   60
      IDE10493-ENG117390-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency   19000 Hz
      IDE10493-ENG117391-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume   60
      IDE10493-ENG126164-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency   19000 Hz
      IDE10493-ENG126165-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume   60
      IDE10493-ENG126166-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency   19000 Hz
      IDE10493-ENG126167-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume   60
      IDE10493-ENG126168-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency   19000 Hz
      IDE10493-ENG126169-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume   60
      IDE10493-ENG117362-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency   19000 Hz
      IDE10493-ENG117363-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume   60
      IDE10493-ENG126170-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency   19000 Hz
      IDE10493-ENG126171-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume   60
      IDE10493-ENG126172-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency   19000 Hz
      IDE10493-ENG126173-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume   60
      IDE10493-ENG126174-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency   19000 Hz
      IDE10493-ENG126175-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume   60
      IDE10493-ENG126176-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency   19000 Hz
      IDE10493-ENG126177-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume   60
      IDE10493-ENG126178-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency   19000 Hz
      IDE10493-ENG126179-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume   60
      IDE10493-ENG117364-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency   19000 Hz
      IDE10493-ENG117365-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume   60
      IDE10493-ENG117366-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency   19000 Hz
      IDE10493-ENG117367-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume   60
      IDE10493-ENG117368-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency   19000 Hz
      IDE10493-ENG117369-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume   60
      IDE10493-ENG117370-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency   19000 Hz
      IDE10493-ENG117371-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume   60
      IDE10493-ENG117372-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency   19000 Hz
      IDE10493-ENG117373-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume   60
      IDE10493-ENG117374-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency   19000 Hz
      IDE10493-ENG117375-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume   60
      IDE10493-ENG117376-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency   19000 Hz
      IDE10493-ENG117377-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume   60
      MAS02809-MAS02870-Check tone   frequency-High note frequency range   4000 Hz
      MAS02809-MAS02871-Check tone   frequency-Medium note frequency range   1000 Hz
      MAS02809-MAS02872-Check tone   frequency-Low note frequency range   100 Hz
Old 01-09-2018, 01:01 PM   #42
quailallstar
Senior Member
Drives: MK7 Golf Variant R-Line
Great job with your DIY.
If I wanted to have driver profile selection installed (switches and coding) 5G0054809 - could I just purchase the kit online like the one found here and code everything myself without needing ODIS?
__________________
2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8t FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
quailallstar is offline   Reply With Quote
Old 01-09-2018, 01:23 PM   #43
sportwagen3
Member
I got everything to work. Thanks George for this guide. Definitely was helpful. The coding was the main issue as to why 47 was not responding. I was able to code the rearview camera, boot logo, and car image after component protection was removed from the MIB and amp.
Old 01-09-2018, 11:31 PM   #44
sportwagen3
Member
I ended up having CP removed and appconnect added remotely. Much cheaper than buying the appconnect key and going to the dealer and paying for labor. I ended up buying the VAS5054 with OKI chip to have it all done remotely. If anyone needs the VAS5054 for the conversion, I'm willing to sell it for cheaper than what you can find online. Just PM me.
Old 01-10-2018, 01:02 AM   #45
George Ab
Senior Member
Thanks. I see we are off topic from MIB1 to MIB2 conversion.
Unfortunately, no. A dealer would have to add the Functional Enablement Code (FeC) using ODIS hooked up to VW Central. When you buy the FeC it comes as a PIN code and when added the FeC will be associated with you VIN at the mother-ship database. This allows the FeC to be re-added later along with all the other FeC associated with your VIN if you need a future replacement of your infotainment. Much cheaper price on that here http://www.allcarpartsfast.co.uk/vw-...4809-software/ then what you provided. Lastly, when you order 5g0054809 the hardware (shown in your picture) and cable comes with the FeC PIN code.
Old 01-10-2018, 01:07 PM   #46
ARi
Member
Drives: Golf 7 GTD
I have got everyone working but the sub is producing vocals along with bass
Also the sound focus does not work on dynaudio profile and only on Individual with the ball
Old 01-10-2018, 08:35 PM   #47
Nuje
Junior Member
Drives: 2015 Sportwagen TDI
Can you outline exactly what you bought (new / used), hardware-wise, as well as what software mods (purchased, coding, what software tools, etc.) you did?
(Cost, too, if you don't mind.)
I was going to go with the hacked unit, but then started hearing people having issues (e.g., random shut-offs) with the ones from APG. So, now back at looking at doing getting MIB2 the pseudo-legit way.
Nuje is offline   Reply With Quote
Old 01-10-2018, 10:14 PM   #48
George Ab
Senior Member
Congratulations!
Old 01-11-2018, 07:29 PM   #49
ARi
Member
Drives: Golf 7 GTD
Has anyone got the coding for the amp latest mib2 amp which has sound settings below the profiles instead of a separate page as I believe this is what I need
Old 01-11-2018, 07:30 PM   #50
ARi
Member
Drives: Golf 7 GTD
It is software SW150 if that makes any difference ?
Old 01-12-2018, 03:33 AM   #51
CarniifeX
Member
Drives: 2017 Mk7 GTI SE
If anyone is looking for a 6.5" screen out of a 2017 GTI, I will have mine out in about two weeks.
The car has 2400 miles on it so everything it mint.
CarniifeX is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
