DIY MIB1 to MIB2 Infotainment Conversion (Part 1)
sportwagen3
Any instructions on how to route the wire for the usb/aux? Did you remove panels on the passenger side or did you remove the glove box? If so, how did you do it?
sprinks
United States
I believe someone here has mentioned previously they basically used a thin stiff wire (think coat hanger straightened) to run the wire over to the glovebox area. That's the way i'll likely approach it as well.
ARi1
Here
Retrofitted dynaudio mib2
The sound is not perfect and the sub is producing sound and bass rather then just bass
Is this coding?
XoneDB4
St Albans, UK
Is this coding?
I’m no car audio expert but I’d have thought a low pass filter in line to the sub would be the simplest solution.
George Ab
Pacific NW
From the article: "I removed the side panel and took a bicycle cable shroud, these work great for fishing cabling. If you don’t have one just go to your local bicycle ship and ask for one they have replaced. House wiring cable is also decent, a clothes hanger is likely not long enough. After removing side panel I started from there and went half way through dash, reached up and pulled down to cubby. Now I could tape USB/Aux yellow and green connectors to my shroud and fish up harness to infotainment unit. Green connector will slide into large connector."
George Ab
Pacific NW
Is this coding?
Not sure what this has to do with a MIB1 to MIB2 conversion.
That said, you may want to check byte 04 and 11 to see if they are set up for external amp (Dynaudio - Fender in US). Not sure if it relates to your Dynaudio conversion.
From article:
"Since your unit is likely from salvage it is already coded with adaptations all sorted. However, you should check a couple of things in the 5F module. Check bytes 4 and 11 if you have a Fender System as the donor unit may not have come from an external amp unit. In my case I did have to change the values to the original values of byte 4 to 00 and byte 11 to 02. Also verify byte 19 is set for USB iPhone fully functionality."
Also, I thought I saw something about Dyanaudio conversion on the Ross-Tech forum.
ARi1
Here
Hi
Thanks for your help and these options have been checked
I think the amp itself needs coding
Can anyone share the coding for a mib2 amp
47 - sound system long coding
As I have a fault saying control module not coded
sportwagen3
I'm getting no response from 47 in VCDS for the MIB 2 amp. Anyone know how I can fix this?
George Ab
Pacific NW
Hi
Code:
         ;SW:5Q0-035-456   HW:5Q0-035-456 ---  Sound System
      ;Component:MIB2_lite_amp H20 0130    Coding:2200000000AAAAAA000000000000
      ;EV_AMPMst12C1Gen2ALPI   1003   EV_AMPMst12C1Gen2ALPI.rod
      ;Tuesday   23   May   2017   12:00:12:51554
      ;VCDS Version: Release 17.1.3 (x64)  Data version: 20170320 DS267.7
      ;VCID: 6DFF3AE7BC589C2932-8038
      IDE10493-MAS03001-Electrical test 2 of   loudspeakers-Mode   automatic
      IDE10493-ENG117360-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency   19000 Hz
      IDE10493-ENG117361-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume   60
      IDE10493-ENG117378-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency   19000 Hz
      IDE10493-ENG117379-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume   60
      IDE10493-ENG117380-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency   19000 Hz
      IDE10493-ENG117381-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume   60
      IDE10493-ENG117382-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency   19000 Hz
      IDE10493-ENG117383-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume   60
      IDE10493-ENG117384-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency   19000 Hz
      IDE10493-ENG117385-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume   60
      IDE10493-ENG117386-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency   19000 Hz
      IDE10493-ENG117387-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume   60
      IDE10493-ENG117388-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency   19000 Hz
      IDE10493-ENG117389-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume   60
      IDE10493-ENG117390-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency   19000 Hz
      IDE10493-ENG117391-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume   60
      IDE10493-ENG126164-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency   19000 Hz
      IDE10493-ENG126165-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume   60
      IDE10493-ENG126166-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency   19000 Hz
      IDE10493-ENG126167-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume   60
      IDE10493-ENG126168-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency   19000 Hz
      IDE10493-ENG126169-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume   60
      IDE10493-ENG117362-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency   19000 Hz
      IDE10493-ENG117363-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume   60
      IDE10493-ENG126170-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency   19000 Hz
      IDE10493-ENG126171-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume   60
      IDE10493-ENG126172-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency   19000 Hz
      IDE10493-ENG126173-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume   60
      IDE10493-ENG126174-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency   19000 Hz
      IDE10493-ENG126175-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume   60
      IDE10493-ENG126176-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency   19000 Hz
      IDE10493-ENG126177-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume   60
      IDE10493-ENG126178-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency   19000 Hz
      IDE10493-ENG126179-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume   60
      IDE10493-ENG117364-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency   19000 Hz
      IDE10493-ENG117365-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume   60
      IDE10493-ENG117366-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency   19000 Hz
      IDE10493-ENG117367-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume   60
      IDE10493-ENG117368-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency   19000 Hz
      IDE10493-ENG117369-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume   60
      IDE10493-ENG117370-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency   19000 Hz
      IDE10493-ENG117371-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume   60
      IDE10493-ENG117372-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency   19000 Hz
      IDE10493-ENG117373-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume   60
      IDE10493-ENG117374-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency   19000 Hz
      IDE10493-ENG117375-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume   60
      IDE10493-ENG117376-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency   19000 Hz
      IDE10493-ENG117377-Electrical test 2 of   loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume   60
      MAS02809-MAS02870-Check tone   frequency-High note frequency range   4000 Hz
      MAS02809-MAS02871-Check tone   frequency-Medium note frequency range   1000 Hz
      MAS02809-MAS02872-Check tone   frequency-Low note frequency range   100 Hz
quailallstar
WOB DJ496
Florida & our Nation's Capital
MY19 MK7.5 GTI Bunny
Great job with your DIY.
If I wanted to have driver profile selection installed (switches and coding) 5G0054809 - could I just purchase the kit online like the one found here and code everything myself without needing ODIS?
sportwagen3
I got everything to work. Thanks George for this guide. Definitely was helpful. The coding was the main issue as to why 47 was not responding. I was able to code the rearview camera, boot logo, and car image after component protection was removed from the MIB and amp.
sportwagen3
I ended up having CP removed and appconnect added remotely. Much cheaper than buying the appconnect key and going to the dealer and paying for labor. I ended up buying the VAS5054 with OKI chip to have it all done remotely. If anyone needs the VAS5054 for the conversion, I'm willing to sell it for cheaper than what you can find online. Just PM me.
George Ab
Pacific NW
Thanks. I see we are off topic from MIB1 to MIB2 conversion.
Unfortunately, no. A dealer would have to add the Functional Enablement Code (FeC) using ODIS hooked up to VW Central. When you buy the FeC it comes as a PIN code and when added the FeC will be associated with you VIN at the mother-ship database. This allows the FeC to be re-added later along with all the other FeC associated with your VIN if you need a future replacement of your infotainment. Much cheaper price on that here http://www.allcarpartsfast.co.uk/vw-audi-seat-skoda/vw-audi-seat-skoda-5g0054809-software/ then what you provided. Lastly, when you order 5g0054809 the hardware (shown in your picture) and cable comes with the FeC PIN code.
