FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Marketplace > Vendors Classifieds > Engine and Exhaust
Reply
Thread Tools Display Modes
Old 06-30-2016, 01:50 PM   #1
Boomba Racing
GOLFMK7 Official Sponsor
Boomba Racing's Avatar
Drives: 2016 GTI
Blow Off Valve Adapter [BOV] - Boomba Racing
Available now!
No aftermarket tuning required. Will work on stock tune or aftermarket tunes.
This high performance adapter mounts between the OEM bypass valve/solenoid and the turbo housing, causing the unused charge air to vent to atmosphere (VTA) giving off the well known, but distinct sound all turbo owners know and love! The adapter bolts right in with the included longer bolts, no other modifications or tuning are required.
Installation is simple (car does not need to be raised) and all mounting hardware is included.
Precision CNC machined out of high quality aircraft grade billet aluminum.
Available in your choice of color: Onyx Black, Royal Blue, Race Red, or Pure Aluminum
Link to buy: http://www.boombaracing.com/2015-volkswagen-gti-blow-off-valve-adapter-bov/
Sound clip: https://www.youtube.com/watch?v=w9nLqwhx_D4
Installation video: https://www.youtube.com/watch?v=ANMlnqM_psE
Boomba Racing is offline   Reply With Quote
Old 06-30-2016, 03:22 PM   #2
Boomba Racing
Drives: 2016 GTI
Sound clip!
Old 07-01-2016, 09:18 PM   #3
Boomba Racing
Drives: 2016 GTI
BUMP!
Old 07-03-2016, 03:20 AM   #4
rjtrout
Senior Member
Drives: 2016 VW GTI
Ordering this tonight
rjtrout is offline   Reply With Quote
Old 07-05-2016, 02:20 PM   #5
Boomba Racing
Drives: 2016 GTI
Quote:
That will be shipping out first thing today for you!
Old 07-07-2016, 07:24 PM   #6
Boomba Racing
Drives: 2016 GTI
Installation video is now available!
Old 07-07-2016, 09:47 PM   #7
murtaza911
Senior Member
Drives: 2016 Golf 1.8t Tsi
Does this work on a TSi 1.8t? My Tsi is a bit too tame sounding. Miss some of the sound from my old turbo cars .
murtaza911 is offline   Reply With Quote
Old 07-08-2016, 04:46 PM   #8
Boomba Racing
Drives: 2016 GTI
Quote:
We have not yet tested it on a 1.8 yet, but we have strong reason to believe it'll work there, also.
Old 07-08-2016, 08:21 PM   #9
murtaza911
Senior Member
Quote:
Any discount for me to test for you?
Old 07-09-2016, 10:17 PM   #10
MK777
Member
Drives: MK7 1.8 SEL
Are you guys located in wood dale il?
MK777 is offline   Reply With Quote
Old 07-10-2016, 08:07 PM   #11
cj_gti
Senior Member
cj_gti's Avatar
Drives: Golf gti mk7
Is this just for noise, or does it actually function like an upgraded bov/dv? Will it hold boost better than the stock valve?
Build thread: http://www.golfmk7.com/forums/showthread.php?t=13099
cj_gti is offline   Reply With Quote
Old 07-11-2016, 08:03 AM   #12
snobrdrdan
Senior Member
snobrdrdan's Avatar
Drives: a VW
Send a message via AIM to snobrdrdan
Quote:
Noise only
__________________
'17 Tiguan
snobrdrdan is offline   Reply With Quote
Old 07-11-2016, 03:50 PM   #13
Boomba Racing
Drives: 2016 GTI
Quote:
Yes we are located in Wood Dale, Illinois! Not far from O'Hare Airport.
Quote:
Originally Posted by snobrdrdan View Post
Noise only
Performance isn't changed from the installation of this part. This is more for the sound aspect of things. You do protect your engine a little bit from blow-by though because the oily air that was being recirculated into your intake before, is now being vented out into the atmosphere. We currently have a full BOV replacement going through testing which replaces the stock valve.
Old 07-11-2016, 04:00 PM   #14
bluekid99
Senior Member
Drives: 2015 Volkswagen GTI
will this work with a upgraded DV?
__________________
2015 GTI SE -IS38 APR, BFI Stage 2 Mounts, Unitronic IC, ECS Throttle and Outlet Pipes, RS7 Plugs, CTS Intake, CTS Turbo Inlet Pipe, Niche Targa M129 18x8, VWR Springs, Unitronic Downpipe, Magnaflow CB, 034 Dogbone Mount, 034 RSB, Super Pro Endlinks, ECS Pendulum Mount, BoombaRacing Weighted Shift Knob, CTS Short Shifter, BMS Clutch Stop, SB Stage 3 Daily, 034 RSB, RS3 Coil Packs
bluekid99 is offline   Reply With Quote
Old 07-11-2016, 08:47 PM   #15
Boomba Racing
Drives: 2016 GTI
Quote:
Yes . It will let the DV vent to atmosphere rather than intake.
Old 07-11-2016, 08:52 PM   #16
bluekid99
Senior Member
alright i was only asking bc i have the go fast bits DV+ so i was curious
__________________
Old 07-11-2016, 10:07 PM   #17
Boomba Racing
Drives: 2016 GTI
You should be fine!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
