TimmyTbonez235
- New jersey
- 2018 GTI SE
Yeah title says it all. Looking to buy a new or slightly used hpfp upgraded piston. Let me know what you got. Thanks
Thank you, I hope you get the car working properly. If not lmkI might have my Autotech one for sale. Just depends on if we can get my damn car to work properly with this damn MPI kit.
What was the issue?Ok, everything is working and I am good to go to sell my Autotech HPFP to you.
What was the issue?
Question, why not use both the HPFP and the MPI?Ok, everything is working and I am good to go to sell my Autotech HPFP to you.
How is there less wear and tear on the cam lobe? The upgraded pump only alters the displacement of the pump — probably slightly. Change in force imparted to the cam lobe is probably negligible.If I had MPI, I would probably go back to stock hpfp (swap with someone). less wear and tear on the cam lobe and not that hpfp upgrade is unreliable but stock is going to be more reliable. and that fuel is just not needed. You can easily get all the fuel you need via MPI.
I’m also guessing that your tune can be altered for the additional fuel.How is there less wear and tear on the cam lobe? The upgraded pump only alters the displacement of the pump — probably slightly. Change in force imparted to the cam lobe is probably negligible.
Yep, I’m currently running CTS turbo MPI, but I’m thinking about using the autotech pump in addition to the MPI.You have to, if you want to use MPI.
