Lord_Flexington
- Syracuse
- 15 MK7 GTI LP PP
Hmmm may have to hop on this
What boost tap do you recc? i dont have one, looking for it jus tto run my 5 bar AEMMatt, you should also mention that you have a boost gauge and that's why you have that "T" fitting with your AEM 5bar and boost tap. For those, like myself, that don't have a boost gauge, you would connect the 5bar MAP sensor directly to the boost tap.
Just got one, thanks!APR.
Tuve dificultades para poner mis manos en un arnés de cableado para ejecutar el sensor de mapa de barras Aem de 5 para poder impulsar el impulso a más de 30 psi. Así que decidí hacer el mío y haré algunos para otros.
El precio es de $ 37 e incluye envío continental gratuito a EE. UU.
¿Por qué ejecutarías la barra de 5 en lugar de la barra de 4 que algunas personas están ejecutando? Creo que Ed hace un buen trabajo explicando el problema y los síntomas.
Incluye:
Los 3 conectores
Fijado e impermeabilizado
La longitud es de 12 pulgadas de largo.
* EL SINTONIZADOR REQUIERE UNA SINTONIZACIÓN PARA EJECUTAR UN SENSOR DE MAPA DE 5 BARRAS *
Piezas adicionales necesarias
Sensor PUT de 4 barras, pieza # 0281006059 (Bosch) # 03K906051 (OEM)
AEM de 5 barras: https://www.summitracing.com/parts/avm-30-2130-75
[ATTACH = full] 169005 [/ ATTACH]
Hello, please tell me how I buy your harness for the 5 bar sensor. Pay pal.I had a hard time getting my hands on a wiring harness to run the Aem 5 bar map sensor so I can push boost over 30 psi. So I decided to make my own and will make some for others.
Price is $37 and includes free Continental US shipping.
Why would you run the 5 bar instead of the 4 bar some people are running? I think Ed does a good job explaining the problem and symptoms.
Includes:
All 3 connectors
Pinned and waterproofed
Length is 12inches long.
*A TUNE IS REQUIRED BY YOUR TUNER TO RUN A 5BAR MAP SENSOR*
Additional parts needed
4 Bar PUT sensor part #0281006059 (Bosch) #03K906051 (OEM)
AEM 5-Bar: https://www.summitracing.com/parts/avm-30-2130-75
Includes:
All 3 connectors
What?Correct because you would have greater precision in the psi of the turbo. even if you won't exceed 27 psi.
This part confuses meAdditional parts needed
You need to upgrade 2 sensors, the put location 4 bar is what is needed to be able to request over 29psi and the 5 bar map location is for a secondary type of fueling calibrations for the ecu in addition to the AFR.So if I am running OEM currently, I need the AEM 5 bar and harness correct?
It is correct you need the 5 bar bar and the harness as well as the other 3 pieces that you need to updateSo if I am running OEM currently, I need the AEM 5 bar and harness correct?
Still waiting…What?
Please tell me your question because I can't see it in the chat or forum, thank youStill waiting…
