amullo
- Stockholm, Sweden
Forgot to add......
usually fit you want to go narrower & smaller for winters then down one size in diameter & one size in width..............that would mean 205/55/R16..............& for those who want to fit bigger summers then up one size in diameter & up one size in width...........anything more than this affects the handling even more!
Personally I wouldn't have fitted 195/65 R15 winters when your car comes with 225/45 R17 as summers............
But it's your car, .............just please be aware that posting as you did could leave other people to do the same as you, which is not strictly best practice in all countries.
BTW in winter I am more concerned about Black Ice which we get lots of! A wider proper winter tyre will get more grip than a narrow tyre of the same design! Also remember that with a wider tyre you can run a lower tyre pressure which is better for more grip! Look at all those big balloon tyres on big 4x4's for driving over snow in Iceland, even where I am same 4x4's do this for winter (not as big thought)!
The basemodel Golf comes with 195/65-15 tires from the factory and there are no major diffrences between a GT-spec cars suspension and the base model suspension. The biggest reason for fitting a larger rim is looks, not roadholding. Especially not roadholding in the winter when slush, snow and ice are packed on a tarmac surface. The icelanders your referring to need a wide tire with low pressure to spread the weight to ride on top of the surface, essentially "aquaplanning" ontop of the snow to keep from going through.
On the road, your trying to do the opposite. a narrow tire will have an easier time then a wide one, since a wider tire will need to "plow" through the snow. And you DONT want to get on top like the icelanders.That means surfing and aquaplanning. NOT good.
For reference
http://www.tirerack.com/winter/tech/techpage.jsp?techid=126
They actually use the 225/45-17 -> 196/65-15 as an example of downsizing.
Do whatever you want, Its YOUR car (even if you havent even drivven it yet?), but dont go against well known and well established facts aswell as VW´s own usages of tire width aswell as someone who has drivven the car for 10 000 kilometers/6000 miles in winter conditions already. 196/65-15 is recommended for the Golf and is even fitted to factory vehicles. Go for a slightly lower sidewall with 16" if you want, but keep the width of the tire as narrow as is possible for true winter conditions. Or dont. Your call.
I´ve also included a screenshot of VW Swedens guide for recommendation for winter size rims and tires. As you can see, It clearly states that 15" is the right size for the Golf VII GT 2.0 tdi DSG.
Perhaps the UK is diffrent, I have no idea.
The recommendation for my, givven that I drive about 40 000 Km´s/25 000 miles a year is to use studded tires, but we opted for friction ones.
