videoguy009
- Saint John N.B.Canada
Can anyone tell me what size winter tire they are running other than the 225 40r18 stock tire and still be within the 3% that is required for safety.
Keep in mind that while going to a narrower tire like a 215 or 205 will be better for cutting through deep snow, it will give you less traction on the dry and wet pavement for braking, cornering, and accelerating in those conditions.
Nearly everything with tires is a tradeoff. You might actually find better results with a different winter tire than with a different size. What winter tire did you use this past season?
Hercules Tires Avalanche R-G2
I had a couple damaged belts from hitting a pot hole early spring and couldn't replace it because they were discontinued.They were built in Russia.What is a good winter tire.
