Winter Car Care 101
mk7_bk
Creating a thread on this. Search sucked. Google search brought up 1 dead thread. So I'm going to create my own. Would love all tips and tricks that everyone has and I will include all in the second post. Thank you
mk7_bk
Winter Care Areas
Wheels: Use stock or "steelie" wheels.
Tires: Snow/ Snow performance. Really
depends on your area. Many might get away with A/S tires.
Wash/Seal: Wash undercar after snow storm, wash car every 2 weeks if you can. Clean snow from wheels after big storm
Check fluids: Coolant level, Washerfluid level (add if needed). Use cold type washer fluid
Tire Pressure: Check tire pressure as it will loose pressure during temperature drop (roughly 1psi per 10°)
Items to add in car: Ice scrapper/ Brush, Gloves, emergency kit, jumper cables, Flashlight, Small bag KittyLitter, heavy blanket (incase you get stuck and are cold), Small Shovel, Snacks incase you get stuck
Wipers: Put wipers in service mode (before storm) / Replace wipers if needed.
Windshield: claybar windshield, add rain-x when dry to help snow/ice
Floor Mats: Use Monster Mats, or buy weathertech mats
Tips, Tricks, Useful items
Tip: Clean off tailpipes before starting car
Tip: Go to touchless carwash
Tip: Don't let gas level go below 1/4
Tip: Test your battery with a volt meter before winter starts
Tip: Wax before the first big storm
Tip: Check spare tire/ gear to make sure that is all good
Tip: Use de-icer spray in am when windshield is frozen
Lastly: Move to warm area as many jokers have said
Resources / Videos
Good deicer I used: https://www.walmart.com/ip/Prestone...MIvZmpssbJ5QIVVf7jBx2ehQElEAkYEiABEgJ-Z_D_BwE
Use a pre-spray when at all possible and avoid contact washing until salt has been removed. Always avoid touch washes (machine). Do go through touchless that hit the undercarriage.
https://www.ammonyc.com/shop/ammo-boost-winter-wash/
In addition a lot of good points i would otherwise type are well laid out in these videos:
https://www.youtube.com/watch?v=eJCQ0X5E5Ig (car wash tips for winter)
https://www.youtube.com/watch?v=yTsUSDD0Zzk (how to wash in the cold)
https://www.youtube.com/watch?v=_18VlRvxTsk (winter prep/ wheel wash)
c72k
CA
BMW
I also keep cat litter in a zip lock bag in case I need extra traction/get stuck. A blanket is also not a bad idea. Some may consider switching to 0W-40 if car is kept outside or temps are super low
vincevtr
Ontario
MK7 GTI
clean snow out completely from your wheels after a big snowfall.
Wash the car every other week, or even more frequently if you can.
ZuMBLe
NY
Alltrack 6MT
Make sure washer fluid is winter type that won't freeze. Not all fluids are the same.
Ridebjj
lasVegas
Move to the desert. Drive all year on high performance summer tires. :D
ElectricEye
Central NJ
Put a nice, heavy duty blanket in your hatch - just in case you ever wind up stranded in the cold and need to wait a long time for help.
miked617
Boston, MA
21 VW GTI
Wax it before the first storm hits.
Use a volt meter to test your battery before winter. Better to replace in the fall than the dead of winter.
Dont let gas drop below a 1/4 tank.
Use a drive through touchless wash when its too cold. I have a membership for "unlimited" washes. Comes in handy....
Make sure tailpipes are clean before starting/cleaning off the car.
Put wipers in service mode to prevent them from freezing to the windshield.
If you have a roofbox, or can spare the trunk space, carry a shovel with you at all times. Has come in handy for me more than once.
