Golf R Clubsport build
greekspec2
California
17 Golf R 17 BMW X1M
wing is getting a final polish....
Pickleahoy
Deland, FL
2016 Golf R
White end caps was the right choice, it will help make the wing look smaller and blend in more. How is this mammoth mounted? Do you have to drill the stock spoiler?
greekspec2
California
its not that big....the factory side wings on the glass get replaced with the Oettinger ones, the main wing is glued to the tops of those and the center post is glued to the factory wing with end caps screwed in
CeeBeeKay
Westchester, NY
that's why I picked up a pair of these....
View attachment 179575View attachment 179576
I love the fit of the stock NA seats, but prefer the immediacy of manual adjustment in my mkIV GTI, like these.
Also, a shame the stock perforated leather seats don't ventilate. This summer I was really seeing the value in that. These are a big upgrade in the looks department! From a Scirocco R, or Golf R?
greekspec2
California
16 Scirocco R same seats as Golf
Gptuners
KY
2019 GTI S
Actually, I like it. It looks like the only rear spoiler capable of generating downforce, other than the real GTI TCR spoiler (which requires a different hatch) and R Theory's racing wing kit. Where'd you buy it?
Gah! Don't be surprised if I end up getting the same one. 😒
I don't like the rear spoilers that go up at an angle (I like more straight back) so this one, the iSweep, and the carbon fiber ECS are on my high list.
TheMuffinMan
How difficult was re-pinning of those seats? Curious how close the two seats were, might have missed it but I'm guessing they retain heated function? Looks like they're manual adjustment.
greekspec2
California
Just reuse your original harness, attach seat position sensors to the inner rails, install a new passenger base heater/POD pad and thats it.
draza74
OR
17 GTI
Loving the build man! I feel pretty confident on buying Wiechers roll bar now.
In terms of install, is it pretty easy?
And how much of a difference did it make in terms of stiffening and handling?
greekspec2
California
Install is fairly easy and if you have a 4dr it's a breeze to slide the main bar in by yourself 2dr seats gotta come out
It defiantly stiffened my chassis up I'm sure if it attached at the rear inner wheel wells it would stiffen even more, remember this Wiechers Clubsport version is mainly meant to attach belts which I have the belt bars that will be welded in
Handling it's hard to pinpoint what it has contributed since I've changed R compound tires and bump/rebound settings quite a bit since installing
Now I might sell it only because I want the main hoop with cross bars and or might get one of Wiechers version B which is a half cage
Below the black cage is Wiechers and the red gage I believe is a Cardiff Motorsport
greekspec2
California
finally got my wing back did a quick test fit without the side extensions gotta remove the factory ones first, glad I went with this Oettinger TCR wing reminds me a lot like the A45 GLA45 AMG wing.
