Anyone here have experience with the 034 Front Sway Bar? What do you think of it?
I have an 034 RSB on my GSW 4Motion and am considering adding the front. I would like to know if the 034 front bas specifically has a significant effect on body roll . It is advertised as a 40% increased rate compared to the OEM bar I have now. Compared to some aftermarket FSBs, this is a low increase, but I do not know what % increase is noticeable. I would also consider the H&R front bar, but it's tough to get stiffness specs out of them and I want to make sure it'll be a good match for my 034 RSB.
For reference, I have Golf R springs, B8 shocks, caster bushings, eurosport camber mounts, rear subframe inserts, solid trailing arm bushings.
Thanks
Thanks
