Bottom line: If you’re running these LCAs/bushings on a car that sees track time make sure to frequently inspect them. If you’re thinking about buying them, don’t.
I decided to try out Whiteline’s full replacement stamped steel LCAs with their poly bushings pre-installed (WA302L/WA302R) after sales and discounts got them down to $50 each.
Initial impressions after installation were great. They definitely helped sharpen up the front end giving the steering a more precise feeling and helped reduce the car’s tendency to wander under heavy braking.
After a couple months of street driving, 2 auto-x days, and 1 HPDE day I started to notice some inconsistency mid corner during my 2nd HPDE with them installed and had to start feeding in more steering corrections after turn in than I was used too. This event was also my first after switching to a different tire setup so I initially just assumed it was a trait of the new tire.
While swapping my wheels and brake pads back to my street setup I went through my usual post track day inspections and found the rear bushings on both arms were failing.
LCAs were installed with new hardware following service manual procedures including torquing to spec with the suspension loaded. Car is still on stock springs and DCC dampers with an Eibach FSB set to the soft setting, so not an extreme setup by any means but may just have too much suspension travel for these bushings. They may survive on a car with coilovers and high spring rates that doesn’t see as much of the suspension’s full range of travel. The front bushing on both LCAs still look perfectly fine.
