Which oil spec
Jdreg
I’m seeing in VW oil charts that they have gas engine oil spec 502 through 509.
I getting a 2018 gti. Which spec should be used. Is the higher number an improvement over the lower and therefore can be used in its place.
Thanks
Joel
TN
502 spec is fine for the 2017 GTI.
Unless they updated your engine I would assume the same holds.
I run Motul 8100
Clem604
Thanks
The 502 and 504 specs are approved for use in the GTI. I own a 2018 GTI and I use Motul 8100 X-Max.
funks
Dublin, CA
Snag the Castrol Edge 0W40 A3/B4 Euro Formula from Walmart (less than 30$ for 5 quarts). It's a Class 4 Oil - PAO (unlike the other Class 3 synthetics) - and meets all the highest Euro Mfg requirements - including VW 502. Not sure why some people keep pushing Liqui Moly, twice as much and isn't officially tested at VW 502 (only recommended, not approved) specs unlike the two listed here.
API SN, API SM, API SL, API SJ, API CF, ACEA A3/B3, ACEA A3/B4
BMW Longlife-01
Meets Ford WSS-M2C937-A
MB-Approval 229.3/ 229.5
Porsche A40
VW 502 00/ 505 00
I believe Mobil-1 FS 0W40 meets the requirements as well (pretty sure the FS one is Type 4) but did lose it's BMW LongLife-01 spec (compared to Castrol).
API SN, SM, SL, SJ
ACEA A3/B3, A3/B4
MB-Approval 229.3
MB-Approval 229.5
VW 502 00/505 00
Porsche A40
Note: the small FS label near the handle.
dm33
Raleigh, NC
API SN, SM, SL, SJ
ACEA A3/B3, A3/B4
MB-Approval 229.3
MB-Approval 229.5
VW 502 00/505 00
Porsche A40
I'm attempting to research this at the moment. I looked up the SDS for Mobil 1 and its looking like group III. Wonder if they changed the formulation when they lost BMW LL01 certification.
The Mobil 1 SDS says: "Mobil 1 FS 0W-40"
Revision Date: 20 May 2016
Ingredients lists 40-70% "DISTILLATES, HEAVY, C18-50 - BRANCHED, CYCLIC AND LINEAR".
I'd say that makes it a group III. It does include 10-20% decene which is a PAO.
Cameron1292
Florida
Anything approved by vw with their 502 will work fine. Cheaper options include the stated Castrol and mobile 1. I've always used mobile 1 0w40 on my mercedes. Used it for my first change on my mk7 then after tuning switched to liqui moly 5w40. Engine runs a few degrees cooler, and oil is cleaner when I change it. It is not only recommended for vw502 it is most definitely approved by vw themselves. A simple check on the bottle or website will show you. Same with motul, and a lot of other high quality oils. Don't over think it. Go with something approved for warranty reasons and your fine.
Sent from my ONEPLUS 5T using Tapatalk
ManInTheClouds
OK
BMW is selecting 0w-20 for better fleet fuel economy ratings.
I'd suggest people get the SOPUS/Pennzoil Platinum Euro, as it's made with newer technology and has more stringent approvals.
20ls01
Im using m1 0w-40($10 for 5 quarts after rebates) when factory oil is changed. Don't need to overthink oil or spend big bucks. It won't make any difference as long as you use the oil with the proper approvals and weight.
MikeGmk7
PA
I never thought I'd be saying this, because after 40+ years of changing oil in my own motorcycles and cars I've never really "felt" a difference in how a vehicle performed with different oils, but I thought I'd pass along the following: Last two oil changes on my 2016 GTI, i used the Castrol 0w40. Seemed fine, engine sounded happy, etc. But I did notice some slight surging running up through 2nd and 3rd gears, and sometimes in 4th. I thought it was the stock mpg-oriented tuning or maybe my imagination, but.....I just changed the oil again, this time using 5W40 Castrol Professional from a kit offered by ECS Tuning. The hesitation/surging is GONE. Gone completely. The engine also sounds a bit sweeter at idle, less "clatter."
Anyone else have similar experience? I'm sticking with 5W40 until further notice.
ieddtech
Canada
I noticed the last posted date for this is 2018. It's now 2020. Has there been any changes since this list was last updated? I just did my oil change on my 18 Autobahn...I buy the Castrol Professional Edge 5W40 which...for some strange reason is less than what is it anywhere else. Including Wallyworld. But as I purchased this last 5L of oil...one of the techs in the shop told me VW is changing from Castrol to Mobil 1. I know the Castrol Edge is a Class 4...but he couldn't remember if the Mobil they're changing to was. Anybody know anything more about why they changed to Mobil after patronizing Castrol for decades? And if this new Mobil is a Class 4?
zinfamous
MD
Specs have not changed for 18 and earlier MK7s. The spec for 19s did change. 508.xx. 0w-20
also, 2019 is still "Castrol." If they are switching to Mobil, then it's with the 2020s, and in NA, those Euro '20s won't be a new model here for another 2 years anyway, right?
RennWerks
Hither n Yon
Comparison of 0W-20 (0W-30 within link) weight oils now widely available in Europe: https://www.ato24.de/en/blog/comparison-0w-20-engine-oils.
In PDF form: https://www.ato24.de/media/wysiwyg/ATO24_Ölanalyse_0W-20_VW_50800_50900_komplett.pdf
Note that Castrol's II IV FE and VW's G052577 performed identically. Thus, it's my hunch that Castrol is bottling VW's G052577. (That may change soon.)
Footnote of sorts: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5326048/mobil-1-esp-now-sold-in-5qt-jugs#Post5326048 in Canada. $35 CAD is a really good deal for this particular oil, especially if you're one of those who believes that running a 0W-40 weight oil in a 2019 GTI risks your immortal soul. No doubt this will soon be sold in the U.S., too.
