jay745
What Would Glenn Danzig Do
- Slightly Outside Chicago
- Mk6 racecar, Tacoma
Might as well be a what oil do I use thread.Shut up!
what clutch should I get!?!
Ok but after you tell me which stage 1 to getMight as well be a what oil do I use thread.
Miracle Whip is not mayonnaise.Ok but after you tell me which stage 1 to get
This guy is speaking the language of gods!Miracle Whip is not mayonnaise.
NahDo I really need an intercooler?
Cool thanks.
YW. Just put some vicks vapor rub on the cold side of the turbo.Cool thanks.
Would Vaseline work? And which side is the cold side?YW. Just put some vicks vapor rub on the cold side of the turbo.
No. Neither would Mayo.Would Vaseline work? And which side is the cold side?
That's the thing...they are opinions. Most will recommend what they have or like. A lot of the lowering springs are designed around the stock dampers. Some companies will list their spring rates. If you look...the rates are not significantly higher than the stock. At only 20k miles...I think your stock dampers will be ok. Will they perform like aftermarket ones...nope...but will work "fine" for street driving and spirited driving here and there.
Regarding coilovers. If you live in a place where it snows a lot and the roads are salted. There is a good chance that after a while they will start to corrode...and the adjusting collars can seize up on you. If you set and forget...it won't be a big deal...but if you want to adjust...seized collars can be a huge headache.
For reverse rake, I think it depends on whether you are DSG or MT. DSGs are heaver in the front and that can cause them to sit lower, balancing out reverse rake.Thanks! Definitely towards a spring/strut combo vs coil overs after doing some more research. Seems to suit my needs more.
I'm leaning towards H&R OE or EIbach Pro Kit at the moment as they seem to pair better with Bilstein B6 or Koni yellows
I'm noticing that most springs will cause the car to have a "reverse rake" look. Are all you guys running MQB or TT spring pads?
In my case, it still reverse raked more than I'd wanted and I still installed the TT pads despite being DSG. On top of frequently carrying cargo/people, the extra clearance doesn't catch side eye from the overzealous cops in my city.
