Where Does The Garage Door Clicker Go?
Chogokin
So Cal
GTI Sport | Audi A3
I keep it in the sunglass holder. The remote slightly bigger than the key. I’ve never noticed it rattling. You can always use some felt in the holder.
sterkrazzy
United States
Turbo. Blue.
George Ab
Pacific NW
There have been posts on using an adding a button at stick shift button location and wiring to your gutted garage door opener and stashing guts in area under stick shift. Easy and clean retrofit.
I purchased a VW mirror that had Homelink (programmable garage door button).
Salami
North Carolina
MK7.5R
I installed a new garage door opener last weekend and the new remote is tiny compared to the old unit.
The old unit fit nicely in my sunglasses holder and was out of sight that way. But, the new one is so much smaller, it would rattle around in the sunglass holder. I don't want to carry it on my keychain.
So, where does everyone keep their garage door clicker?
Thanks, Bob.
Do you use the sun-glass holder for actual glasses? If not get some thick foam and cut to shape of sun-glass compartment, then cut out the shape of the remote. The foam will hold the remote in place.
cb1111
Newbie
Virginia, USA
If you park your car outside then you'll not want to leave your opener in an obvious location (cup holder, visor etc.) as that will give someone access to your house.
Get a set of that velcro like stuff that is made to hold ez-pass to the windshield. that stuff won't lose stickiness if it gets real hot.
Stick it somewhere where it isn't obvious (under the seat, passenger side of the center console etc. - use your imagination)
dlhoovler
Cleveland, Ohio
2017 GTI Sport 6MT
I removed the clip from the back of the remote and applied the hook side of Velcro tape. It sticks securely to the carpet at the front of the door pocket.
MonkeyMD
I always worry about this and when i park outside, i take it off the visor and stash it out of sight or even just take it out completely
FSTSNAL
Sacramento
2019 DVP Spektrum R
And this is why a homelink mirror is the better option. Only works with ignition on. Someone breaks in unless they Hotwire the car or use a kessy repeater they are not opening your garage door.
Keehs360
Denver
Mk7.5
Set up a smart house. Get the proper peripheral for the garage motor. Or just get a myQ
then tell Siri or google or Alexa to close it and open it
works for me. Plus its a flex to say hey Siri open the garage in front of others too lol
FSTSNAL
Sacramento
2019 DVP Spektrum R
works for me. But if a flex to say hey Siri open the garage in front of others too lol
It works ok. Issue I have is an update a few months back was causing my garage to go offline almost every day. It seems fixed lately but was an issue for a while.
ElectricEye
Central NJ
Visor for me.
Reach up and push the button when approaching or leaving the garage.
As for it leaving a mark if removed, I'm not going to remove it 'till I get rid of the car.
