When do you typically change spark plugs?
kingkhan
Canada
I changed mine out based on the factory interval. you can pickup a set of OEM plugs off of rockauto for around $45 CAD so it's a pretty cheap maintenance item.
It's a straightforward DIY if you want to tackle it yourself.
Mk7GolfDisease
Canada
2017 Golf 1.8T TSI
Aright sounds good thanks for the advice nah my bf can tackle it i dont mess with anything under car hood other then oil change or wiper fluids lol
kingkhan
Canada
If you do end up ordering from Rock Auto, make sure you use the 5% off coupon. Also order anything else you might need like wipers or filters since you are paying for shipping.
This one expires on Nov 15th: 120638971109717100
You have to enter in the where did you hear about us box.
Mk7GolfDisease
Canada
2017 Golf 1.8T TSI
Thank you appreciated your help
russiankid
PA
I will do them earlier, like 20k miles. I do not like the idea of anything (especially threaded things) sitting in my engine for 60k miles. I definitely want to get some anti-seize compound on those threads ASAP.
Don't see how this is an issue. I would also advise against anything on the threads unless VW calls for it. Anti-seize acts as a lubricant, you can over torque the plugs without even knowing it and bugger up the threads in the head.
rallymaniac555
ChiTown Burbs
2020 GTI S MT
the plug replacement interval is mostly driven lately by the fact that you want to get them out of the head before they weld themselves into the aluminium the heads are made out of nowadays. The platinium and iridium plugs that are so widely used in new cars now can last 90k miles plus but if you don't at least check them at 60k and put them back in then good luck trying to get them out at 90k or after.
The plugs you will pull out at 60k will look almost brand new so when you inspect them and they look great and hold the gaps, you can go ahead and put them back in and then replace at 90k or 100k later. It's the motion of moving the plug threads before 60k that counts.
Mk7GolfDisease
Canada
2017 Golf 1.8T TSI
Personally, if OP is going to pull them out and inspect, at 71k, I'd just go ahead and replace them anyway no matter what they look like. it's near enough to the interval.
See i called a vw specialist of a mechanic that i dealt with before for a full transmission flush and new one in etc he said no too early probably at 90 to 120 thousand in km clicks no idea who to believe lol
Look in your manual.
StorableComa
Long Beach, USA
17 GSW S
My 2017 schedule for all vehicles except electric for USA (included booklet with manual) states every 40k Spark plugs should be replaced in the 1.8 and 2.0T. Shopdap.com says 60k and I can't seem to find my revised maintenance card to double check. I changed mine out at 40k, granted I picked the car up used and figured it was cheap preventative maintenance on a car I knew little about, YMMV.
Mk7GolfDisease
Canada
2017 Golf 1.8T TSI
I read maintenance booklet too that came with my car and it stated otherwise literally said every 4 years whatever km you are on you change it didnt say in km intervals just said every 4 years is...
