ggweci
- Toronto area
Hi all,
Looking for some guidance. I have a 2019 Rabbit model and really like the OEM Pretoria wheels. They fit the car so well.
But, I do want a flush stance with the wheels pushed out in line with the fenders. The car is a daily driver.
The way I see it, I have two options:
Option 1:
Keep the OEM wheels and add Space Flush Kit. This is the easiest option, but offers limits in tire size/width and has potentially added weight (I'm reading mixed info on the 18" Pretoria wheel weights). Replace the tires with something better at a later date.
Option 2:
Sell the OEM combo (should get a good return, as they are near new) and buy a good quality, economical, and lightweight 18x8.5" wheel set (i.e. Konig, Superspeed, etc) with new rubber. This allows me to run a wider tire and likely reduce overall weight.
Now, my main questions are:
Thanks in advance for the input.
Option 1:
Option 2:
- What are the pros/cons of running these two setups?
- Is there a weakness to the spacer setup?
- Assuming the same tires, will I gain a huge difference in traction going from 225mm to 235mm (most likely choice) or 245mm width?
- Anything else that I'm missing?
