wheel offset question
66RBS
Portland
2003 Jag. XK8
Re 2016 GTI SE with performance pack. (larger calipers?)
stock wheel and tire are 225 40 ZR 18
wheels are 18 x 7.5 x ? offset
If I install 18 x 8 x +45MM wheels ( Enkei EMK3) will these move the tire outboard more?
tmw2442
Mk7 R
stock offsets for mk5+ VW wheels are usually 45ish or more. Aftermarket wheel designs generally have more caliper clearance in spoke design. If tirerack sells the rim you are looking at...they will tell you. I would be more concerned with proper hubcentric rings...as the enkei centerbore most likely doesnt match 57.1...
El_bigote_AJ
Las Vegas
2019 GTI bunny
Austin’s are +49et
swcrow
7.5 GTI/'29 Ford
Barely noticeable…. You’ll still need spacers
chrislane31
CT
18x8.5 et45 is the normal aftermarket set up and either play with spacers or run et35 if you want aggressive.
66RBS
Portland
2003 Jag. XK8
So if my offsets are approx equal the back of my 8” rim is approx 1/4” closer to the suspension than OEM 7.5” rim and the street side is approx 1/4” wider
Are you saying I will need 1/4” spacers to move the wheel street side?
swcrow
7.5 GTI/'29 Ford
… 25.4mm = 1”
You'll need more if you want to be flush with the fender...all depends on what you like
