Wheel hop damaged my GTI
bbroecker37
Tampa Florida
2016 VW Golf GTI
Hey guys, I was driving my car and tried to launch it at a stoplight. I didn't use launch control or anything. Traction control was also on at the time. I just gunned it and it started to wheel hop violently. I wasn't at full throttle either. I let off the gas but it was too late. My car is now making a grinding noise and also vibrating. It does go away if I let off the gas or accelerate slowly. I jacked it up, removed the front wheels, and noticed nothing abnormal. The axles look as good as new. I'm guessing something else is damaged but I don't know what. So I took the car to a VW mechanic and I'm waiting to hear back from them. I'm hoping it's nothing serious.
I'm stage 2 from IE. I also have BFI stage 1 engine mounts and a dogbone insert. So I'm surprised it wheelhopped to begin with. Usually, I don't have any at all.
MonkeyMD
Transmission mount also might be loose. Happened to me & would get vibration on acceleration. Went down a rabbit hole until we figured it out
bbroecker37
Tampa Florida
2016 VW Golf GTI
Snapping or cracking the dogbone mount isn't unheard of, especially with an insert.
Good idea, I'll have to check mine. I didn't think it could be an issue but that makes sense.
I did try to rock the engine to check the mounts with a pry bar and it didn't really budge.
Jmitchell4873
Fort Leonard Wood, MO
Mk8 GTI
If your dog-bone and engine/trans mounts are in good shape, the next spot I'd look would be the LCA's. It's possible that you tore one or more rubber bushings and now you might have an alignment problem on top of your wheel hop issue.
Giuseppe Busso
Greece
Seat Leon mk3 1.8 FR
Could you please upload us a sound clip?
To me it sounds like something from the gearbox. Maybe the shaft's bearing.
BudgetPhoenix
Kansas
2016 GTI S DSG
Hey thats not so bad. Seen multiple people on the forums completely snap their oem dogbone in half with an insert and wreck their radiator fans
MonkeyMD
Good that you figured it out. Shop took apart transmission & replaced the lsd before we figured out it was a loose mount. Really sounds terrible. Know exactly what you mean.
GoatAutomotive
Georgetown, TX
2017 VW GTI SE, DSG
I was worried it was gonna be your LCA bushings. 👀
Those are famously terrible, and are responsible for most wheel hop on cars that have already upgraded the dogbone mount and/or remaining 2 mounts.
Glad you got it sorted quickly, and that it wasn’t your transmission or CV axles! 🍻
bbroecker37
Tampa Florida
2016 VW Golf GTI
Yes, I'm glad it wasn't anything serious. The LCA bushings do suck on this car. I already swapped them out for some SuperPro poly bushings. I got tired of the stock bushing making noise over bumps.
