Why not my friend !You can't remove 6mm off the hub. Not sure what you're talking about. If you want a higher offset, you'll need to find different wheels.
Are you talking about shaving off 6mm from the wheel back pad?
You are saying wheel hub, but I think you mean wheel back pad...
Correct me if I'm wrong.
If I am, like others have said, I would not recommend shaving any material off of the wheel hub that is ON THE CAR.
However if you are talking about shaving off material from the back of the wheel that MEETS the hub on the car then that is something that can be done.
But I have no experience with that...
yes my friend i know that, but unfortunately the seller sold me the wrong one. and then, there is no possibility to send back the wheel and change to correct one.Just get proper fitting wheels?
Ok yeah so I think we were all misunderstanding your question.
Yes, you CAN shave off material from the back of the wheel.
But again this is not something I have any experence with, but I know it can and has been done.
But still, the wheels as you have them right now, should work just fine.
I mean :
Wrong one = ET35
Correct one = ET 45 ~48
Right ?
For that reason I believe if I gonna rework the hub wheels (removing - cut off 6mm of the material) my wrong wheels should be fit as wheels on my VW GOLF GTI mk7.
