Raguvian
- Bay Area, CA
- 2019 GSW 4MO 6MT
I feel like the Sigma 6 needs a nice heavy knob, otherwise it's pretty notchy.
Our bracket is plastic with rubber bushing, so this removes any potential flex, doubt it will be noticeable really. But for the 80 something bucks I spent on them it’s worth the piece of mind.What do these things do that the sigma ssk doesn't already address?
Not the superpin. I know what that's for. What does that bracket and bushings do?
I've done ssk, ss clutch line, delay and swirl valve deletes. Its pretty good now. Preettaaay preeettaaaayyy good.
Good Luck with the install! That’s going to be one hell of an undertaking, I installed the nicer mib2 infotainment and glass display in my car a few months ago and it stands to be one of my favorite factory mods. I can only imagine that this is similar and probably harder with all the wiring and electronic wizardry going on for this upgrade.I don't know what part is real and what part is placebo but I went aluminum subframe and control arms a few months back, with upper/lower pendulum mounts... Love the way the car feels now... I do regret not going dead set kit while I was down that rabbit hole, guess I have more restraint than @uranorab8, lol.
On the other hand my current project speaks to it a distinct lack of restraint...
Two of three required accelerometers for DCC retrofit, I'll clean these up with a soft brush and soapy water... then one of them will be installed under some rear trim in the car and never be seen again.
And a connector for the rear left level sensor...
Turns out that AliExpress DCC harness expects that your car already has this level sensor, which would be connected to the headlight range module for LP cars. Existing wiring would then be connected to the DCC module which would provide that leveling data to the headlight module via can bus. I don't have the LP so I'm adding that level sensor. This is the connector you need.
I have everything except the pin i believe, I would like to do it, but taking the whole console cover off seems like a pita, good luck with the installLast variables left for any potential slop in my shifter. metal cable Bracket/ bracket bushings/ DG super pin. Already have the sigma 6 and Dg shaft bushing installed.
Already did it over the weekend.I have everything except the pin i believe, I would like to do it, but taking the whole console cover off seems like a pita, good luck with the install
good to hear, I know another person on here who tried and broke some clips and had to source the cover. yikesAlready did it over the weekend.
Hardest part was finagling the console our over the e brake handle.
But the results are 100% worth it.
haha! Guess they don’t have googlegood to hear, I know another person on here who tried and broke some clips and had to source the cover. yikes
