What do you use for DSP and tapping into the stock signal? Fender or basic? The only thing I ever really wanted to change about the Fender radio was to add a dsp to get some time alignment settings and the like to adjust the sound stage.Finally gained the bug back to start work on my V3 round of the GTI’s car stereo, lol. Had the 3.5”s and tweets from over a year ago’s purchase but the tm65s showed up yesterday afternoon so i can go full 3way up front. (Been working on the a pillars the last few days as well)
These things are nice and shallow for thier known output and clarity compared to the others I’ve had for stock/v1/v2 lol. so got to test for if they clear without and adapter rings cause I did try them with the current 3/4” MDF rings already on the car and they wouldn’t even slide in with those.
Currently I’m using a LC7i where I cut the 4 factory channels out of the dash directly to it. Then that goes to a Dayton dsp-408 then to the amps and from the amps back to the factory harness behind the radio for the door speaker (tweeters were run as standalone wires since they are fed off the door speakers in a factory configuration.What do you use for DSP and tapping into the stock signal? Fender or basic? The only thing I ever really wanted to change about the Fender radio was to add a dsp to get some time alignment settings and the like to adjust the sound stage.
Dibs for next down the line, when it doesn’t perform the way you want/need. I just need it to turn on a look cool for pictures.
What is that?
My initial thought is it'll be on its way to you. But going to give it a few days to see. I also need to send the seller a message to see if there's a way to change the units from metric to imperial. I'll type up a mini initial review in a bit.
I should note that the gentleman may not know his own ZIP code. Or is possibly dyslexic, in which case I may delete this comment .
Probably the most egregious part. If it makes it through all of you gentlemen and back to me I'm not unwilling to try to hack into the thing and see if that image can be changed. A custom startup image, or no image at all would be quite nice.
But the ZIP code given was not correct. I then took a leap of faith that the gentleman does know I'm which city he resides so I searched that and chose the ZIP code that was most similar to the one that was provided to me.
Glad it worked out. Been meaning to send this for probably a year at this point. From what I remember it was hot outside when I initially tried it. And it's hot outside again.
Nah this is actually crazy hahahahahahahah
