What did you get in the mail or bring home for your MKVII today?
DrFunkalupicus
Topeka
2016 VW GTI S
Aren’t the fronts of the b6/b4 non dcc inverted shocks with an internal bump stop? Asking cause I’m assuming you’re waiting on 1 of the 4 bump stops based on your use of “waiting on the last”
It has different bump stops front and rear, but for some reason one of the fronts sent from the east coast and one from the west.
swcrow
7.5 frankenstein
Suction jet pump recall letter….yay. “If it ain’t broke….”
Cuzoe
tell me more
It's the OEM tow module retrofit kit. In the states it was only sold for the Tiguan and Atlas. I don't know that any MK7 Golfs are tow rated here. But mqb is mqb. And Golfs are rated outside of the US. There's even an electric swiveling tow hitch for the wagon.
The module installs on a bracket in the spare tire well. I'm not sure whether I'll have to cut some of the foam tool kit. Ordered the bracket on eBay from somewhere in the EU. It's a part number for the Golf but not available from the dealers here.
This kit comes with a four pin tow plug. But the module is capable of handling a 7 or 13 and can be wired for that. It comes with the coding document which the dealer would use with ODIS so that all the coding could be done online. But it's just basic coding that can be done with obd11 or vcds. No swap codes or anything like that.
It'll be wired per the Tiguan/Atlas schematic including the additional power wires the Atlas has (needed if doing 7 pin plug) that would be required to charge a trailer battery, although there's basically no chance I'll tow anything.
Having the OEM module and having it coded properly means the trailer is accounted for in a lot of ways whenever the module senses a trailer is plugged in. Brake/stability compensation via the ABS module, higher duty cycle for the cooling system, auto rear parking sensor deactivation, warning for burned out trailer lights, car alarm if the trailer is unplugged with car locked.
I don't know that some/all of these features are not available with some of the aftermarket tow modules, honestly never looked into them. This kid was discontinued a few years ago and my local dealer had one languishing in their inventory. They aren't able to return discontinued parts for credit so i got it for the low.
Jachas
PL
A3 8V
There is the difference between modules of early MK7 (Up to +-2014MY, 5Q0907383 for 2 plug and 5Q0907383A for 3 plug) and later ones (2015+ MY, 5Q0907383B and laters) Early module is from 2 to 3 plugs (Tow wiring, car wiring + optional manually retractable tow hitch), later ones got 3 to 4 plugs (Tow wiring, car wiring splitted into bigger plug for mains powers and grounds, smaller for communication + optional semi-automatic retractable tow hitch)
I retrofitted, manually retractable hitch with newer style module (cheaper pre-made wiring and cheaper modules, at least in my country), only "problem" that status LED's doesn't show if hitch is in locked (green LED, doesn't mater if hitch is hidden or open) or unlocked (red LED, hitch in intermediate position, between hidden or open). But in case of manual and semi-automatic tow hitches, you clearly hear when it's locked because locking is loud.
I can recommend to wire it for 13PIN, as the job is the same (- 2 pins in fuse box, so why not) OEM wiring want you to connect to BCM (CAN + brake light signal)
Cuzoe
@Jachas Since my module is 383L I suppose it would support everything. I may go for 7 pin. The 13 pin may not be common here (or at least doesn't seem to be). I guess I could always use a 13 to 4 adapter. But to be honest I'm never going to connect a trailer or tow anything ?.
Still haven't even put the bike rack on the hitch. And it's an aftermarket 2" receiver, not the OEM swivel.
