Supercrumpet
- Georgia/South Carolina
- '19 Alltrack SE 6MT
Not wishing to re-ignite the rear wiper debate, but my OCD about maximum swept area on car wipers had me searching for a longer rear blade to replace the 'better-quality-than-standard' recommended 280mm/11 inch Bosch A282H I already had fitted.
A 300mm/12 inch option seemed a safe bet, but it turns-out Bosch don't supply one that size with the needed VAG-type mount, with only shorter 250mm and deffo. too-long 330mm options being listed.
In the end I took the plunge on a 12 inch Bosch A300H - which is the correct style of blade, but comes with a KIA/Jaguar mount.
Thankfully, my guess that a bit of applied force with a small screwdriver would remove the KIA mount without damage to the new blade proved correct and fitting the 'VW' mount from the old A282H proved straightforward.
After fitting to the car, I can confirm that there is still more than enough clearance using the 300mm blade and I'm happy in the knowledge that I'm now getting about 7% more wiped area.
I know this is pointless/pathetic/sad, but whatever...
This is actually great info, I'm interested in doing the same with mine next time I need a new rear wiper blade. Would you estimate it adds another 0.5" of length to each end, evenly? Looks like there's barely enough space at the top of my rear glass for a longer blade, and I assume the rear hatch/wiper/glass/everything is the same on our cars since we both have wagons.
