- Phoenix
- 2018 SE DSG
Walmart probably has them.gotta get the heads first somehow
This is pretty slick, not gonna lie!Well not really on the car, more so the extra spare wheel i plan to mount a tire on..
Carbon fiber wrapped stock Austin.
looks greatWell not really on the car, more so the extra spare wheel i plan to mount a tire on..
Thanks!! Only 5 moreThis is pretty slick, not gonna lie!
Thanks man!looks great
Call the Foot Clan.gotta get the heads first somehow
Unbelievably for 80,000 miles they look fine.Changed my spark plugs, Iām pretty sure they were the originals with 80k.
donāt know much about spark plugs, how do they look?View attachment 226865
all of that.
True kick in the nuts this AM. Went to change lanes b/c person doing 35 in left lane, get in the middle lane and saw the rock in the middle of the road at the last possible second.
Sounds unpleasant!I've spent 2 days installing koni sports and mss springs.
Make sure you sand the paint off the bottom of the front struts, get a REAL strut spreader kit, and grease the bottom of the strut. Also, make sure you have both a 16mm and 17mm offset box wrench with 75 deg angle for the rears.
Konis instructions for adjusting the rears is terrible. You need to compress them fully, with in mm of the threads. No possible way to do it by hand, like in the videos Koni has online. You need a mounted vice (protect the threads) or I bolted an L bracket to top of my workbench and drilled a hole to bolt the rear shock shaft to, then pushed in full, set to full soft, then adjusted.
Still couldn't get the fronts the final inch, put wheels on lowered car, backed out of driveway, drove to driveway, the hit from going up the drive, fully seated them.
