Agray
- Washington
What was wrong with the OE end links? I’m on coilovers as well but I never thought of replacing the front end links.
I think we're just about done on my TDI S, words I've said before
If my car was a GTI S that would have crossed my mind. But a lot of these things were never an option on the TDI, even an SEL. We stopped getting them in 2015 and I didn't want a sunroof. Even with the mods/retrofits (not counting my time), I'm in this car for less than a GTI S from a financial standpoint.Did you ever sit back and think "Man, I should have just bought a fully loaded one from the start"?
Hi, I'm interested in making some of the same wiring mods. Could you recommend any wiring instructions or diagrams for say the shifter surround buttons? I purchased all six, though my car doesn't have all the functions, I think I can probably use some of them, like the tire pressure warning or ESP? Also, how did you do your footwell lighting? I started on doing something like that on my MK7 because I used to have this feature in a Saab 9-3 and a Volvo V60 I owned before. Thx.Finally got all this nonsense terminated, cleaned up and labeled. Pics are not all from today but... this is roughly the order of things.
View attachment 200188View attachment 200184View attachment 200186View attachment 200185View attachment 200183View attachment 200187View attachment 200189
Wiring was added for Blind Spot Monitoring, Parking Assist & Aid, ACC, DCC, Lane Assist, Auto Dimming Mirror, Footwell Lighting (front and rear), Heated Seats, Internal Motion Alarm, External Sound Actor, Structure Borne Sound Actor, Rain Light Sensor, Fog Lights, All 6 of the possible shifter surround buttons (No Start/Stop in my car so this switch will control a latching relay to turn the external Sound Actor on/off), I think that's it.
Good grief. Your best option now would be to get new mounts and bearings. Then you wouldn't have a repeat of round 3. Just throw the whole original assembly in the trash.Bilstein B8 (front) install round 3. Round 1 did not have a M14 triple square (had a M12). Total time wasted 30 mins. Round 2 used the 2x4 method of the driver side; took about 3 hours to remove solo. Did not have the special 22mm strut nut tool; total time wasted about 5 hours. Called the shop that installed my springs for a quote for the front shocks only and was quoted $600. They did my springs for $280 so I said f*** that. Bought a complete set of strut nut tools for like $50. Decided to start with the passenger side strut. Took about 3 hours again; it did not want to lift out. Had to bang on it with a hammer too eventually get it out. Tried to remove the strut nut and bent the 7mm Allen wrench. Sooooo the shop that installed the springs must have used impact tools (explains why everything was so fricking tight) and I only had hand tools so that's that. Total time wasted 5 hours again.
Pic of bent Allen.
So it’s my understanding that as you lower a car, the distance between where the endlink mounts to the front sway bar and the strut body shortens. As the stock front end link is non-adjustable in length, it applies more pressure to the front sway bar as the car is lowered from stock height, effectively loading up the front sway bar even when the car is at rest. The adjustable end links allow you to properly adjust the length so that there is no “pre-load” on the front sway bar at rest, which allows it to function throughout its full range of motion when driving.What was wrong with the OE end links? I’m on coilovers as well but I never thought of replacing the front end links.
Honestly driving around down after install I couldn’t feel a difference but I haven’t done any sporty driving with them yet. For 150 bucks and how simple the install is though I thought it was worth it.
Ive never understood that explanation because it’s not loaded at rest if both sides have equal length endlinks. Lowering the car would only have that effect if the sway bar had a mechanical stop that lowering the car pushed it up against, which isn’t the case if you disconnect both links it moves freely through a ton of travel.
Maybe I’m missing something, but a more logical explanation would be if the car was corner balanced and ride height was drastically different corner to corner, then maybe adjustable links would come in handy
From the factory most sway bars sit parallel to the ground when the suspension is at rest on the road (not drooped in the air or fully compressed in a corner). When this is the case, there should be no preload on the sway bar meaning it is not adding any tension to the vehicles suspension. In order for this to happen after you just lowered your car, you need a shorter sway bar end link because now the suspension geometry including suspension lengths have changed.
Yeah I assumed it the same... unless the Links are at un-equal length I don’t see how a preload is happening on the bar cause you lowered the car (both sides)Ive never understood that explanation because it’s not loaded at rest if both sides have equal length endlinks. Lowering the car would only have that effect if the sway bar had a mechanical stop that lowering the car pushed it up against, which isn’t the case if you disconnect both links it moves freely through a ton of travel.
