Desslok
PA
2019 Rabbit
Is your car on stock shocks or aftermarket?
I have Bilstein B8s ready to go with Revo (Eibach Euro) springs and want that Eurosport camber kit. Keep us posted on the camber, please.
GTI Jake
Charlotte, NC
I’m curious too. I have suspension parts stock piled and wasn’t going to add any camber from the top since it’s a nightmare for most people NVH wise. Either way I’ll probably just run the LCA & B14 to see if I like that setup before diving into additional added camber, but it would be nice to have a plan B
blaqsheep
Canada
IS38 GTI
My previous setup was Koni Yellow with VWR springs and SuperPro camber plates. SuperPro plates made no noise but were way too harsh on anything but perfect pavement, I was only able to get -2.1 up front with the deadset kit in. When I installed the Eurosport kit, I pushed the mount towards the engine as far as I could and loosened balljoint nuts to try to gain some more negative camber, will definitely post alignment printout when I get it - hoping for at least similar specs, bonus if it gets me more.
Anthony3o55
South FL
Took her out on her first photoshoot today. Looking nice with the DG springs I installed yesterday
danvilla413
Washington, D.C.
'19 SE 6MT, '04 S2K
Bought an '03 forester so I can keep it out of the salt
Very New England of you! But yeah, I also have a beater ('08 Mariner) to drive in the salt - thankfully DC doesn't get nearly as bad.
imthanick_a
Ohio
I bought a 17 Tiguan a couple months ago for the same reason. My 98 camry finally rusted out and isnt worth a damn anymore so had to upgrade
blaqsheep
Canada
IS38 GTI
So got an alignment this morning, interesting that the right camber is not equal to the left, even with the deadset kit. Wonder if it's worth tinkering with the ball joint to get it equal or let it be. It's also damn near impossible to get the steering wheel exactly center every time I go. It's always been slightly off since the day I bought the car.
Front:
Caster 7.55° / 7.17°
Camber -1.99° / -1.72°
Toe 0.01° / 0.02°
Rear:
Camber -1.70° / -1.69°
Toe 0.03° / 0.03°
Ridebjj
lasVegas
Had manual carbon cleaning done today at 100K miles and holy shit the difference in throttle response and power is amazing. And he said the carbon buildup wasn't nearly as bad as others at that mileage because of my OCC.
Really? Even with no misfires or codes, and not much buildup (no pics?) you can tell?
Anyone else see this?
IanCH
MA
'20 GTI
Front:
Toe 0.01° / 0.02°
Rear:
Toe 0.03° / 0.03°
Well you're looking at a 0.135° deviation assuming its complimentary. Hunter Hawkeye machines have a tight mode camber tolerance of +/- .25° I would say that unless you are noticing any measurable wear difference or steering behavior then you should consider yourself in spec.
tight mode tolerances:
Standard mode camber tolerance is +/- 0.50°
blaqsheep
Canada
IS38 GTI
tight mode tolerances: View attachment 185971
Thanks for this. Previously with the SuperPro plates I was at -2.16° / -2.14° to I was hoping to get it pretty even.
Assuming the same goes with the caster +/- 0.50°, looks like front caster was 7.57° / 7.62° when I first got lowering springs installed.
