Started on clutch, flywheel and rms replacement. Decided not to go nuts and just spend 2 hours per day until it's done. Until quarantine is over, I don't need it.
Last night was the start. Remove airbox, battery and tray, disconnect and remove shift linkages, disconnect starter, support engine and remove trans mount bolts, remove the top trans housing bolts, etc etc. Basically everything that you can do from the top.
After I'm done working around 4, I'll raise it up and start on the next section from below.
