I'm not a gambling man, lol. They get changed out every 2nd/3rd oil change thanks to FCP.43,000 miles without changing plugs?
so I go back to some other variation outside of the tune, which was running fine for 70kI'm not a gambling man, lol. They get changed out every 2nd/3rd oil change thanks to FCP.
https://www.golfmk7.com/forums/index.php?threads/in-process-alibaba-gti-build.429645/Exploring what to do next... CXCB motors are quite expensive used, not sure what A3 motors I can interchange with.
How do you have that Banks gauge mounted onto your steering wheel?Installed new Ruth's, SC Skunkwerks CGH, new Euro Zone Tuning steering wheel and cleaned the air filter.
Now hear me out… what if you ignore the 3”Some hacking away at the set of pillars I picked up from @crxgator. These experimental ones are fender so they have the silver trim but my non-finder pillars have black trim.
Pods are out of the question. And these tweeters are clearly not ideal but I can live with this once I figure out a way to blend it.
You sonofa... damnit those look good. How much?
No idea the guys in Italy and his shop website is hard to navigateYou sonofa... damnit those look good. How much?
Or 42nd draft designs has an offset one that I’m rockingMagic
Or I may have used this:
https://cjmind.com/collections/vw-mk7-2015/products/mk7-2015-golf-gti-r-steering-column-pod
Yea I got to their page, couldn't figure out a thing. I don't want to do any of that, although the results will be an order of magnitude better than what I have going on now. I don't really have the motivation to find a shop that can do it, even ignoring the cost.No idea the guys in Italy and his shop website is hard to navigate
There is this cheap option that will work with the SI measurements with a tiny bit of opening the whole. Then you can plastic filler them in smooth and rewrap the a-pillar.
Tweeter “pod”
How much was it for the speaker and how hard was it to install? Hmmmmm.........Long time coming but external soundaktor speaker finally installed! Several, like almost double digit, exhaust shops said they couldn't (or wouldn't) install it. Anyway, didn't have stainless hardware of the right size so hardware you see will be replaced with stainless after a trip to Home Depot. Wiring will get run through the wheel well grommet at some point, but I did temporarily connect outside of the car... sounded pretty damn neat. And if you don't know what in hades I'm talking about... it's this, although not installed in factory GTD location.
