CaptainRatty
Winston-Salem, NC
MK7 GTI
Means you’re lucky, because worse detonation results in the rod bearings leaving the chat or worst case a rod bending or breaking.
You can pull the oil filter, hold it over a white sheet of paper and cut it open (unroll it) so any chunks fall onto the paper. If there’s bronze bearing material in there that’s when you worry/make plans to rebuild or replace.
The filter was clean. There's still no explanation for the cylinder 3 misfire/hide cylinder, but considering the mileage and it being cylinders one and two with detonation furthest down the line on the rail, fuel injectors and carbon cleaning while they are in there makes sense to me as a next step. I have four of these injectors on the way Bosch 06L906036AK. They are significantly cheaper than the GTI injectors, flow 15% more, and EQT can accommodate them in the tune. Will also probably go with a new, OEM HPFP.
Starting my track prep to get back out on track in October now that it's cooling down in SoCal.
Ordered some Brembo RE10 front enduro race pads, supposed to be comparable to Ferodo 3.12 with much better wear.
Hmmmm, I wonder if they come in a 1001 back plate.?
bobloblawGTI
DC
'19 GTI SE 6MT
So long, Composition Media; Discover Media retrofit is (mostly) complete. NAR 2021 maps installed, no codes thrown. Officially a good day -- big thanks to @brownnugen for renting out his VAS and D-Link tools for the job! Recommended if anyone needs them for an upcoming job.
Daks
Toronto
GTI PP
Are you getting those just for the price and then getting tune to accommodate. Or do you actually want more flow? Note that if you are on aftermarket DP, they can't disable the secondary O2 anymore, so you'll run a CEL if you unplug. Or spacer or whatever...
Nerdy Oreo
Rhode Island
Mk7 Gti S
Not a Mod to the car but my Fiance made me this MK7 GTI Sweatshirt a few minutes ago and I had to share. I think it came out soooo good.
The text on the rear window is the companies I've been getting my mods from and its the same as on the real car.
CaptainRatty
Winston-Salem, NC
MK7 GTI
Purely price, I'll still only run 93 octane and I suppose I'll benefit from whatever margin of added flow they offer. Thanks for the reminder on the secondary 02... I have a spacer that has always worked to keep that code away.
CaptainRatty
Winston-Salem, NC
MK7 GTI
Kdubya
Florida
2017 GTI
View attachment 261043View attachment 261044
This is such a good idea , specially with the name of the companies
Nerdy Oreo
Rhode Island
Mk7 Gti S
DSC808
HI State
2016 GTI SE MT
Interested to hear if that stops your oil use.
Nope. Before it was just oily at the sensor; now its an active drip. Looks to be coming from the sensor area. All the oil pan bolts are tight. Tightened the sensor nuts another 1/8th turn. Might just buy a new sensor, drain, clean the surface and replace.
https://youtube.com/shorts/PG2BbbL1a7g
acoustic_
NJ
2018 Golf R
Changed plugs+coil packs today. Cyl1-4 top to bottom. 41.5k miles, all stock (as far as I know). Car is now unitronic stage1+
Kdubya
Florida
2017 GTI
Got the approval from the wife to get the stock Austin’s powder coated over the next month.. waiting on the sample to come in so i can Look at it in person and go from there
RobertJG25
Niagara Falls, ON
2019 VW Golf 1.4 TSI
carbon_gecko
texas
2016 GOLf tsi 'S'
Finally installed the rear brake upgrade: 272x10 to 310x22. It was not as easy as it should be, I blame 40 percent me, 100 percent volkswagen.
