What causes thrust bearing failure?
20ls01
Texas
GTI 2016
I was reading on this topic and it got me concerned since i have a 6speed manual.
I was thinking..I did the clutch delay valve delete(reduces drivetrain shock) and was wondering if this can contribute to thrust bearing failure.
1. What causes this on our mk7/mk7.5 platform? Bad engine design?
2. Any 2018 GTI's with engine failures because of this?
mr wrong
Franklin TN
This is purely my opinion, and I'm not suggesting anyone bypass an important safety feature, but I don't think depressing the clutch pedal which applies force to the thrust bearing on startup helps since there's no oil pressure. On my earlier manual VW's I always started the car in neutral and never pressed the clutch pedal.
Again this is purely anecdotal.
MSchott
Michigan
Are you saying because it’s not being lubricated due to the cold engine? If so, does the clutch see engine oil at all?
Finglonga
Keeping or resting your foot on the clutch pedal seriously will shorten it's life because it ads a small bit of load on it constantly.
mr wrong
Franklin TN
I'm talking about the un lubricated lateral force applied to the crankshaft and thrust bearing when the clutch pedal is depressed on startup
eXult
Online
'17 GTI SE 6MT
We can't do that on MK7s can we? First manual so I apologize for the newbie questions, but I can't turn the car on without pressing the clutch.
MSchott
Michigan
Sorry still not understanding but I can tell you my 64,000 mile 2017 which has been subject to well over 1500 cold starts has shown no signs of clutch issues. My guess is these issues are more due to poor technique, at least in unmodded cars.
dietcokefiend
Master of Disaster
Ohio
The thrust bearing is sandwhiched between the crank and bearing caps inside the engine block. Its the bearing that keeps the crankshaft centered when pressed on (pressing your clutch pedal works against this bearing).
The clutch is outside the engine, the thrust bearing is inside the engine.
oddspyke
Delaware
2016 GTI, 2018 ZL1
I know there are lots of different clutch designs, but I keep hearing this logic repeated, and it sounds totally backwards to me. The flywheel is fixed to the crankshaft, the far end of which has the thrust bearing. When the clutch is released (foot off pedal), the throw out bearing is relaxed and the pressure plate is pushing the clutch against the flywheel, applying axial load on the thrust bearing. When you depress the clutch, the throw out bearing compresses the pressure plate and should remove the axial load.
Also, I think this is a moot point since our oil pumps fire up before you start the car.
Strange Mud
Small Town CT
Assorted
afik oil pumps are gear driven...VW may have an aux oil pump for turbo cool down but oil pumps really don't run b4 engine does.
interesting idea about clutch delay valve....
russiankid
PA
What you described is not true. The flywheel mounts to the end of the crankshaft and then the pressure plate mounts onto the flywheel. In between the flywheel and pressure plate is the clutch disk which is sandwiched in between the two pieces. When you depress the clutch pedal, the throw out bearing pushes on the pressure plate which in returns loads the flywheel thus pressure on the thrust bearing. When you're not pushing on the pedal, there is no load.
This platform does not have an electric oil pump, only aux water pump. Oil does not take long to reach the bearings as they are already coated with oil and the oil filter canister has an anti drain back valve to build pressure nearly instantly.
The issue, in my opinion, is design and assembly flaw. Hundreds of thousands of engines are produced that have a clutch mounted to them without issues including VW engines. If the bearing was improperly installed, you get premature wear and then it falls out.
Jacobmk7
NC
2015 GTI S 4dr DSG
Pretty sure there’s no aux oil pump, the sound you hear when you open the door is the LP fuel pump priming. There is an aux coolant pump built into the thermostat/water pump housing to cool the turbo during shutdown though.
To have oil pressure before you start you would need a Pre Oiler.
